crank start die or crank no start try this
Like Tree3Likes
  • 2 Post By wb2kki
  • 1 Post By rckstein
Old 10 Dec 2018, 06:09 pm
Default crank start die or crank no start try this
Had to get towed this morning. First, car would start and and quickly stall. This happen a few tries then no crank no start.
Towed to mechanic long story short they reset the computers by disconnecting battery for a few seconds.
Look up service bulletin 08-007-08 Rv. A 2006-2008 PT cruiser among other Chryslers.
Hope this helps someone in the future. Also thank goodness for AAA.
Mike
06 PT Cruiser Basic with manual trans.
Carl48 and RickinPA like this.
Old 10 Dec 2018, 06:32 pm
rckstein's Avatar
Default Re: crank start die or crank no start try this
Here is what is contained in the referenced TSB:
RickinPA likes this.
Old 08 Feb 2019, 06:19 am
On a 2008 PT with TIPM, which is the main IOD fuse ?
Old 08 Feb 2019, 07:21 am
rckstein's Avatar
In the Service Manual is this:
It's identified as the fuse in cavity 18
But then in the Owner's Manual, it identifies the fuse in cavity 18 as:
40 AMP Green - ASD Relay Contact PWR Feed
Do you have a copy of the Service Manual?
If not, I can send you a link to download a copy from my DropBox.
Old 08 Feb 2019, 02:24 pm
Did a bunch of internet research on this and it looks as if fuse 18 is the IOD fuse for the first gen PTs with a power distribution center.
On the second gen PTs with the TIPM, the IOD fuses looks to be a pair 7 & 8.
Again, FWIW, this is from information found on the internet and not taken from any official source.
no crank no start Jkustow Tech & Performance Forum 16 13 May 2016 12:38 pm
No Crank No Start!!! josh_tolle General PT Cruiser Discussions 3 04 May 2015 07:30 pm
no crank no start PLEASE HELP ljw14 Tech & Performance Forum 29 26 Mar 2015 07:39 pm
03 No crank, No start sassylisey General PT Cruiser Discussions 11 11 Sep 2014 10:52 pm
CRANK BUT NO START clifford General PT Cruiser Discussions 3 27 May 2014 11:15 pm
