Mysterious noise from front end....
Old 18 Dec 2018, 11:10 am
Default Mysterious noise from front end....
Hi All,
My 2005 PT GT Rag Top has developed a "groaning/grinding" noise coming from the front end as it starts to roll. Took it to Chrysler but they couldn't pinpoint it or fix it. Took to my regular shop the front driver side bearing and hub was replaced (bad according to them) noise remains. They also gave up.
It is only audible when you start driving then goes away after you get up to speed. I hear it mostly when I begin driving at slow speed out of my driveway and alley. Once up to speed I can't hear it.
So I'm stumped also any help is appreciated.
Thanks
Old 18 Dec 2018, 02:41 pm
bubba_1952's Avatar
Default Re: Mysterious noise from front end....
Check your front sway bar bushings and replace them if worn. These can cause a lot of noise.
Bubba
2004 Limited Edition Platinum Series Dark Graphite Metallic Clearcoat Turbolight A/T
Old 18 Dec 2018, 09:58 pm
Lots of possibilities.
I say check your brakes.
oldthom likes this.
03 Turbo AutoStick
107K
Cranny
Old 18 Dec 2018, 10:06 pm
oldthom's Avatar
Im with GotToGo, mine does it every morning coming out of the driveway. Humidity makes the brakes swell a bit overnight. I hear it only in the front and it stops at the first stop sign at the end of the block.
2004 LE "Dolly" 61K miles
Old 19 Dec 2018, 12:09 am
Originally Posted by Pacho View Post
Hi All,
Thanks
Does the groaning/grinding noise come back after you get up to speed and slow down again?
Old 19 Dec 2018, 12:21 am
Bubba
I will I was reading another thread earlier about that
Old 19 Dec 2018, 12:26 am
I didn't mention it....I forgot
Brand NEW Power Stop brakes all around These are AWESOME!!!
https://images-na.ssl-images-amazon....L._SL1500_.jpg
Old 19 Dec 2018, 08:25 am
Was it making that noise BEFORE you got the new brakes put on?
Old 19 Dec 2018, 06:31 pm
It started waaaay after the brakes were installed. The noise doesn't change with the brakes on or off. It appears to me that is coming from the center of the engine compartment.
Old 19 Dec 2018, 06:57 pm
rckstein's Avatar
What was the actual item # of the brake kit that you got? Or can you provide a link to the actual ad that you got them from?
When I search Amazon for the Power Stop brake kits, the Amazon filters all say that they don't fit the '05 PT:
PT Mysterious Back Wheel Noise jiblition Wheels, Tires, Suspension 2 19 Dec 2015 09:59 am
Mysterious Rattling Noise Gone Hoosier Tech & Performance Forum 16 25 Aug 2013 08:09 pm
"Mysterious" turbo engine noise...??? Gary04GT Turbo Performance 76 21 Aug 2006 08:28 am
mysterious rear knocking noise was found FIXED!!:) Ctown General PT Cruiser Discussions 3 01 May 2006 12:40 pm
update on that mysterious rear knocking noise Ctown General PT Cruiser Discussions 6 25 Apr 2006 09:55 am
