Noise from power steering
Like Tree3Likes
  • 2 Post By MJKnight
  • 1 Post By Macgyverman1123
Old 18 Dec 2018, 06:26 pm
ptprice's Avatar
Default Noise from power steering
SOOO BIG has a slight squealing from what I think is the power steering unit when I turn it through lock to lock. I checked the fluid level on the hot side of the dip stick in the power steering unit when I finished driving this afternoon and it showed adequate. Right to the hot line on the cap dip stick. What might be causing this squeal?
In retrospect there were all new belts installed earlier this year during a major timing belt change. I don't recall hearing this noise right after the install. Could that new belt loosened a bit? Doesn't a loose power steering belt usually squeal at just at the end of the wheel turn? I normally depend on the opinion of more learned PTers than me. thanks, Happy PTin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 19 Dec 2018, 05:11 pm
ptprice's Avatar
Default Re: Noise from power steering
I rechecked the power steering fluid on the cold side of the dip stick this morning and that side of the cap dip stick reading was OK too. At first attempt from up top I couldn't reach the belt. Is there a way to reach in from above and check the belt tension by pushing on it?
Old 20 Dec 2018, 02:43 pm
MJKnight's Avatar
No you have to take the wheel off ...
Then the spash panel..3 bolt..
The power steering belt has a tensioner
To keep it tight ...
I've been in there a lot lately. .
Replaced the high pressure hose
, new belt..and new fluid(ATF+4)
Old 20 Dec 2018, 07:49 pm
Macgyverman1123's Avatar
Could be the tensioner. I just replaced mine when It exploded the other night. The worst part was getting the new belt up and around the P/S pump pulley. Whole thing took about 45 minutes.
ptprice likes this.
Old 21 Dec 2018, 07:49 am
ptprice's Avatar
So it's probably just belt noise and not the power steering unit going bad?
Old 21 Dec 2018, 10:18 am
MJKnight's Avatar
Hard to say...without actually hearing it..
Old 21 Dec 2018, 11:52 pm
ptprice's Avatar
I drove over to the shop who did major work on SOOO BIG earlier this year and asked them to listen to the "noise". The consensus was it's just a normal sound the power steering pump makes turning from left to right, lock to lock. I hadn't heard it before because most of the time I have the A/C on.
Power Steering-it takes power just to steer it 05PTGT General Turbo Discussions 8 29 Jan 2013 08:37 pm
Sounds Like Power Steering Noise Cajunsim Tech & Performance Forum 1 31 Dec 2008 07:14 pm
Power Steering Noise topdownvert General PT Cruiser Discussions 3 29 Nov 2008 01:49 am
Power Steering Airconditioner belt noise macster General Turbo Discussions 3 04 Sep 2003 06:54 pm
Power Steering Noise dxrinc Tech & Performance Forum 3 11 Nov 2002 04:06 pm
