Heater not working
Like Tree5Likes
Old 19 Dec 2018, 09:31 pm
Default Heater not working
My 2008 Cruiser heater is only blowing slightly warm air. anti-freeze level good.
Engine heat indicator slowly drops from middle when I turn on fan.
Thanks for the help
Old 20 Dec 2018, 01:51 am
Default Re: Heater not working
Thanks for the help
Did it gradually do it or quickly?
Old 20 Dec 2018, 11:26 am
Hi Steve.....it happened in just one day, I had great heat then just slightly warm air. But it coincided with my 1 year old battery going bad and needed replacement.....everything on the same day or so.
All the switches seem to work ok, blower motor is fine. The temp gauge gets up the 1/2 with the heater off then when I turn the heat on itís a little warm air for several seconds then the temp gauge drops then itís badly noticeably warm.
I have a thermostat coming tomorrow but for me thatís a guess that it may be the problem.
Thanks for the help Steve and Merry Christmas too
Old 20 Dec 2018, 01:43 pm
I would suggest doing a diagnosis before replacing the thermostat.
I would suggest using a thermal gun to get temperature readings.
Are you located where the environment is very cold right now?
Old 20 Dec 2018, 01:51 pm
rsrocket1's Avatar
I assume your fan is blowing strongly and you've turned the heat knob up and down several times along with the vent selector switch (face/feet/defroster).
Just making sure you check the free stuff first before tearing into the cooling system and spending any money.
Old 21 Dec 2018, 09:50 am
Not very cold in NY so far so the heater isnít a big issue but it will be soon.
Less heat is coming out now....hopefully new thermostat will make a difference
Old 24 Dec 2018, 11:14 am
I'd do a flush on the heater core if it were mine. Just remove both heater hoses and put the garden hose on one pipe and blast it out. You might want a shot piece of hose off the other pipe into a bucket to see what it catches. Then reverse the flow and blast it the other way.
Old 26 Dec 2018, 05:37 pm
Thanks Chuzz
I replaced the thermostat today simply because itís 10 years old and easy to do but didnít help the heater. Going to govyourvroute flushing out the core pet your instructions.
1. Hoses through fire wall to heater core are hot
2. Rotating the selector on right side from cold to hot allows me to hear inside the dash that something is happening. The blue sends cool air and the red sends barely warm air.
Process of elimination points to clogged heater core.
Thanks for the input
Old 27 Dec 2018, 09:28 am
Let us know if that works. If not, I'm sure there will be other suggestions.
Old 27 Dec 2018, 12:23 pm
My friends on the forum did it again. My heater was putting out zero heat and after investigating the dashboard work to get at doors and actuators I was close to panic mode. After changing thermostat which did nothing I went with one poster that recommended flushing the heater core......
Connected a garden hose to hot water from my dog grooming van, flushed for 15 minutes then switched hoses and flushed another 15 minutes. Put it back together and if I could hang a hotdog in front of the heater vent I could have lunch now.
Thanks to all who suggested remedies to my problem. You are ROCKSTARS
Heater & Ac not working right iowasprintfan General PT Cruiser Discussions 6 29 Jan 2016 06:37 am
Heater Mode Selection Not Working essendy General PT Cruiser Discussions 1 14 Jan 2016 12:06 pm
AC/Heater Blower Not Working Nick Tech & Performance Forum 3 19 Dec 2014 11:32 pm
02 Blazers heater not working kenlesher Tech & Performance Forum 3 29 Nov 2009 01:48 pm
Block Heater, Rad Hose Heater, Which?? kb0nly Tech & Performance Forum 13 23 Dec 2008 03:47 pm
