Rear hatch light on, but not when pressing the brakes
Like Tree4Likes
  • 2 Post By pt06
  • 2 Post By mechanicalhorizon
Old 27 Dec 2018, 07:09 pm
Default Rear hatch light on, but not when pressing the brakes
Just this morning I noticed the light that indicates the rear hatch being opened came on and stayed on.
No chime or anything, it just come on and stays on when I start the car, even when driving.
But, when I press the brakes it turns off.
Could this be a fuse issue? There's also condensation in my car (I live in Seattle so it's very wet this time of year) so could the moisture be messing with the fuses?
Otherwise the car is fine (except I do need to change my front brake pads).
I have a 2004 PT cruiser 2.4 Liter Ltd Ed Turbo with about 140,000 miles on it.
Old 27 Dec 2018, 08:05 pm
ajhockey3's Avatar
Default Re: Rear hatch light on, but not when pressing the brakes
Sounds like something is shorted out
2006 PT Cruiser Base 2.4L NA $250
Old 28 Dec 2018, 12:28 am
Are all 3 tail lights working with the brake off and the brake on?
Old 28 Dec 2018, 06:19 am
I would check the grounds for the tailgate. --- And check the taillights for water buildup inside the assemblies. Water buildup is not uncommon in PT's.
Handy_Cruiser and circus like this.
Old 28 Dec 2018, 01:18 pm
Is this something that would cause my car to fail an emissions inspection?
Cause I have to have one and get my car's registration renewed by the end of January and I can't afford another costly repair.
Old 28 Dec 2018, 02:11 pm
It might not be an expensive repair. The best thing to do is to answer the questions on some of the posts on this thread that does not require any tools.
Old 28 Dec 2018, 05:13 pm
OK, it looks like the rear lights work fine. Turn signals as well. I didn't see any water in the taillight assemblies either.
Old 28 Dec 2018, 09:48 pm
Macgyverman1123's Avatar
Check for water in the backup light assemblies. They are the closest to the ground and can get water from a decent puddle. I had one on the right that was cracked and it would fill with water whenever it rained, which would either blow the bulb or short the turn signal on the rear right side. Finally replaced it this week.
If you need new backup lights, i have 2, one good, one cracked, you can have them for free if you need. Just pay S+H.
Old 27 Jan 2019, 05:48 pm
I think it was just some moisture somewhere in the vehicle, it stopped a couple days after I posted the issue and hasn't come back since.
Tags
rear hatch light brakes
Left brake light won't work when pressing down brake pedal ReeseBear Tech & Performance Forum 9 16 Dec 2016 01:39 pm
Dome light added to rear hatch sanatanadharma Interior Accessories Forum 28 05 Jan 2012 12:03 am
rear hatch jimhoysa Sound and Security Forum 0 07 Dec 2010 11:45 pm
Help..rear hatch satownplayer General PT Cruiser Discussions 3 09 Dec 2007 10:21 am
Rear Hatch Open light stay on? KingKole02 Tech & Performance Forum 5 13 Jul 2004 01:25 pm
