Miss fire and clogged catalyst, hmm.. coincidence?
Old 30 Dec 2018, 03:49 pm
Default Miss fire and clogged catalyst, hmm.. coincidence?
Bought the car showing these codes. Found a leaky injector that stopped leaking by the time I finished cleaning them. No codes for a while then both codes came back simultaneously. Will a rich mixture cause a P0420? I hope.
Old 30 Dec 2018, 10:29 pm
Default Re: Miss fire and clogged catalyst, hmm.. coincidence?
What was the code for misfire?
Old 31 Dec 2018, 10:20 am
303, which happened to be the cylinder with the leaky injector.
Old 31 Dec 2018, 01:56 pm
I would suggest changing the cylinder 3 fuel injector with another cylinder fuel injector. This would eliminate the fuel injector causing the code 303 to trigger if you don't get different misfire code.
If it does not stop triggering the 303 code I would do an engine compression on cylinder #3. If your engine compression is low enough it will not fire all the time and raw fuel will be going to the CAT. Isn't your engine light blinking randomly when the issue comes up?
Miss fire, code P0171 thefish General Turbo Discussions 25 02 Sep 2018 09:12 am
Pt miss fire #1 cylinder? drumrooster Tech & Performance Forum 23 09 Mar 2014 05:52 pm
miss fire pcptcruiser2006 Welcome New PT Cruiser Members 17 04 Feb 2013 04:08 pm
engine miss fire bhunt41 Tech & Performance Forum 0 14 May 2012 09:37 pm
Strange Miss fire nuke72 General Turbo Discussions 12 22 Feb 2006 07:04 pm
