2007 pt cv front wheel problem
  • 1 Post By pt06
Old 02 Jan 2019, 09:14 am
Default 2007 pt cv front wheel problem
my daughter has a 2007 pt convertible , a few weeks ago she drove over a large pothole and now the car squeeks when driven , i did jack it up and there is sideways movement if i grab the tyre at 3 and 9 o clock but nothing if i grab from 12 to 6 o clock, i checked the track rods and they are tight and the rack has no free play , but there is definite movement sideways, i did order some wheel bearings but i'm thinking it might not be that, any thoughts
Anthony
i'm thinking its not wheel bearings as there is no movement top to bottom
Old 02 Jan 2019, 09:31 am
Default Re: 2007 pt cv front wheel problem
I'd check for a broken tie rod end or end link on the sway bar. Could be the end link because they're not all that strong anyway. If not one of those, check the ball joint.
Old 02 Jan 2019, 10:09 am
when i grab the tyre the track rod(tie rod) doesn't move , i feel like its coming from the centre of the wheel but i cant see , i am going to take the wheel off tonight to see if i can see better. sway bar might be possible
Old 03 Jan 2019, 08:14 am
If it feels like it's in the center, it sounds like the locknut could be loose. I don't see how that could happen because the torque on them is high. Maybe the cotter pin broke and that nut has come loose? IDK I'm not really a mechanic, although I DID sleep at a Holiday Inn Express one night.
Old 04 Jan 2019, 08:43 am
This is a two man job. One twists the tire back and forth. Another under the car with a good light looks for the problem. ----- Be safe!
chuzz likes this.
Help with wheel hop on 2007 DWBinRI Turbo Wheels/Suspension/Handling 5 06 Dec 2016 09:21 am
Front Wheel Hub Bearing The Problem... or Not.. scoleman69 Wheels, Tires, Suspension 6 23 Aug 2016 03:53 pm
"Creaky" front wheel problem... HELP! Tobymelodeon Wheels, Tires, Suspension 9 23 Sep 2014 09:07 am
Groan/creaking sound when turning wheel right (front right wheel) 2k2ptc Wheels, Tires, Suspension 8 02 Sep 2012 10:52 am
Rear Wheel vs Front Wheel OD difference moparmadness Turbo Wheels/Suspension/Handling 0 20 Sep 2011 01:23 pm
