Help!! Lost keys in vent on dash!!
Like Tree56Likes
Old 10 Jan 2019, 11:08 am
Default Help!! Lost keys in vent on dash!!
I really need help..my husband put the keys on the dash and they slid into the open on top...how can I locate them? And where can I get a key....since that was our only one!
Old 10 Jan 2019, 11:14 am
Default Re: Help!! Lost keys in vent on dash!!
post a picture of where it fell in... and there is of course zero chance of a spare in the bag with the owners manual, right? in the compartment under the passenger seat? or the jack compartment in the rear? it would really help to know where exactly it fell...
Old 10 Jan 2019, 11:48 am
rsrocket1's Avatar
One of these would help:
https://www.harborfreight.com/digita...era-61839.html
In the future, get some spare keys and have them programmed. 2 keys with remotes cost me less than $30 on ebay and I know a very fair locksmith who cut them and programmed them for $50. The going rate for programming them is closer to $100 and a dealer will charge a couple hundred each.
The first time, he cut 4 and programmed 3 for $75. Last year, he cut 2 and programmed them for $50
Old 10 Jan 2019, 11:57 am
Sorry about this. It will be a pain to recover them.
You will need to remove the top dash panel to access the defroster duct.
Then if lucky, dropping a magnet at the end of a cord into the duct will attract and hold and you will be able to carefully pull out the key (keys and ring?).
Others on this site can detail the panel removal steps.
If the keys fell in too deep, recovery may require removing the heater box.
ptprice and rsrocket1 like this.
Old 10 Jan 2019, 12:02 pm
Thanks, the guy we bought it from was supposed to give us the spare and never did, so I'll definitely get some made.
Old 10 Jan 2019, 12:05 pm
None of that, previous owner only gave us the 1 key.
Old 10 Jan 2019, 02:09 pm
They tried a coat hanger and magnets, couldn't find them.
Old 10 Jan 2019, 02:12 pm
Pics won't post. It fell in the vent that's on top of the radio, near the glass.
Old 10 Jan 2019, 03:25 pm
Sinbad's Avatar
Demist. Your grille must be broken.
the dash top is easy to remove
Pull the door seals away from the top of the window to the bottom of the dash
Pull the A-pillar cladding on each side *in towards the centre of the car* and the clips should free. Remove the cladding pieces.
Pull the dash top towards you and lift it clear - the vents now open and you should be able to hook around for your keys.
If you cant find them, search the forum for removing the glove box and lower dash - the vent ends up in the fan ultimatley, so you might find the keys in taht if you take the ducting off.
sanatanadharma and nj318 like this.
_________________________________________
'07 2.2 CRD
Old 10 Jan 2019, 05:53 pm
Keys are almost always brass (non-magnetic).
They use brass because:
1. it's easy to cut
2. it's a somewhat "slippery" and soft metal that minimizes wear on the lock pins
If the key had a split-ring attached, the rings are usually steel and magnetic. (But it probably wouldn't have gone down the hole if it had a ring attached.)
Once you get the dash top off, if you can spot the key, you might be able to retrieve it with a 3-prong grabber, or use some sticky tape (sticky side exposed) on the end of a stick.
Good luck.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Lost My Keys!!! Do I Have To Tow To Dealer??? myjeephatesme General PT Cruiser Discussions 15 16 Jan 2017 02:45 pm
Lost Keys lurchy Sound and Security Forum 10 03 Jan 2014 05:24 pm
lost my keys felipeferras General PT Cruiser Discussions 16 06 Apr 2012 12:01 am
lost keys michael18 Tech & Performance Forum 4 30 Mar 2012 11:48 pm
lost keys & remote elacua Sound and Security Forum 4 23 Feb 2006 11:18 pm
