Thermostat housing problems
Like Tree6Likes
  • 1 Post By bob2006
  • 4 Post By myckee
  • 1 Post By ajhockey3
Old 11 Jan 2019, 10:18 pm
ajhockey3's Avatar
Default Thermostat housing problems
Let me give you a little timeline.
Got the car running November 2017, noticed a small coolant leak from the thermostat housing. 1-3 drops a night, left it for the time being as I spent a lot of money getting the project running.
Feb 2018, got a new thermostat gasket, and while I was in there I replaced the thermostat too
Dropped a bolt, lost it, in a pinch got a bolt from homedepot, was a shitty grade and I snapped the bolt
few days later I tapped it out and put a new Doorman thermostat housing.
Few months ago I noticed a few drips of coolant would drip from the rad hose, it had an aftermarket hose clamp (that sucks, not fit for the car)
my plan was let it leak out until the resovoir was empty then replace the hose, I got a new hose and thermostat housing together from a junk yard, low km car.
I did an oil change on my car at work because it was slow and the guys were looking for something to do, there was a ton of coolant on the oil pan and splash guard, I popped the hood and the thermostat housing is leaking a ton, is it possible the housing went bad after just a few months or did I possible damage the block outlet from extracing the broken bolt? It just seems weird a brand new housing is bad again....
will be replacing this weekend, anything I should do so this isn't happening a lot?
Not sure what napa warranty is for Dorman products, I only have had to return one part (Bad napa wheelbearing) and they gave me my money back and asked no questions
2006 PT Cruiser Base 2.4L NA $250
Old 17 Jan 2019, 10:31 pm
Default Re: Thermostat housing problems
Doubtful...
To the best of my knowledge the bolt does not intersect "fluid".
So even if the extraction was a bit rough it is highly unlikely that you created a pathway from the thermostat housing through the block.
If you are getting coolant in your oil it may be the head gasket.
_PTGT03 likes this.
Old 18 Jan 2019, 01:07 am
_PTGT03's Avatar
well are you checking your torque level for these t-stat housing bolts ? I believe they are metric 8mm, that's going to be in-lb level . next, you need to determine why theres water in the oil. thats a different issue here
Old 18 Jan 2019, 07:21 am
You might look at the radiator to see if it's spewing at the seam of the tank end. May only do it after getting hot.
Old 18 Jan 2019, 08:53 am
Guys he said he had coolant ON the oil pan, not in it, so not an issue.
When you replaced the plastic thermostat housing, did you clean and ensure the block outlet was flat? If you have crusted oxidation or old coolant or burrs from your drilling and tapping, the thermostat housing will not get a proper seal. You may have to flatten it. As well, the aluminum corrodes so it may have been pitted on either the thermostat surface, or, if you removed it from the block, on the block side as well as the head. If there is pitting on the block side or on the head, as there was with mine, I cleaned it up and smeared silicone there and then put a new gasket and have had no troubles.
Anyway, I would go to the junkyard and get another "block outlet" and get rid of the not so nice "fixed" one and go from there.
Old 18 Jan 2019, 01:32 pm
Thanks for pointing that out.
Makes a world of difference.
Old 18 Jan 2019, 11:23 pm
Once I had coolant on the oil pan and it would come out of the air bleeder on the coolant thermostat mount after it warmed up.
I had tried to loosen it once and it seemed it might break off so I didn't get it snug enough upon re-tightening
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 19 Jan 2019, 10:54 am
ajhockey3's Avatar
I feel like kind of an idiot, I replaced the t housing again, and it still leaked, but from the overflow hose, added a hose clamp and no leaks.
Old 19 Jan 2019, 05:38 pm
We live and learn, AJ. Nice job of figuring it out, anyway.
Old 19 Jan 2019, 05:47 pm
ajhockey3's Avatar
got a new housing under warranty, thermostat gasket was $1.9, got the coolant from work for free.
could be worse
chuzz likes this.
Thermostat and thermostat housing ajhockey3 PT Pass It On 0 18 Nov 2018 07:08 pm
Car temp climbing after thermostat and thermostat housing replaced. superjew78 General PT Cruiser Discussions 23 04 Jun 2014 02:37 pm
thermostat housing gasket soyomb General PT Cruiser Discussions 4 06 Feb 2013 09:21 pm
Thermostat housing cowboyinboxers Tech & Performance Forum 11 20 Oct 2012 06:51 pm
Thermostat housing replacement SRT8guy Tech & Performance Forum 5 12 Nov 2008 12:43 pm
