Key replacement
Like Tree3Likes
  #21 (permalink)
Old 22 Jan 2019, 08:26 am
Default Re: Key replacement
It was pretty easy to do, man. Just remove the cover, take a long zip tie and run it around the module, place the key flat against the bottom of the module and tighten the zip tie. DONE! Put the cover back on and use a $2 Walmart key to drive it whenever you need to. Lose a key? Remove the cover, cut the zip tie, drive to Wally World, get another half dozen keys made and zip tie the chipped one back where it was, put the cover back on and you're ready to go to 6 more bars! LOL
circus likes this.
Oil pan replacement USNavyVet Tech & Performance Forum 5 21 Mar 2016 06:45 am
FAN REPLACEMENT? sgmex Tech & Performance Forum 3 27 Mar 2013 11:09 am
2001 PT - Engine mount replacement needed with Oil pan replacement? SanPT Tech & Performance Forum 14 23 Sep 2012 08:49 pm
Oil Pan Replacement - OEM? SteveG22 Tech & Performance Forum 8 21 Oct 2011 01:40 am
