PT Cruiser Forum (http://www.ptcruiserlinks.com/forum/)
-   General PT Cruiser Discussions (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/)
-   -   Key replacement (http://www.ptcruiserlinks.com/forum/general-pt-cruiser-discussions/66574-key-replacement.html)
PTloser32805 20 Jan 2019 02:06 pm
Key replacement
He guys,
Lost my keys last night. I have the extra key with out the chip.
I got a quote for $165 to have a locksmith make me a new one.
Is there a cheaper way?
rckstein 20 Jan 2019 02:48 pm
Re: Key replacement
Just don't call the same locksmith that this member did :eek:
http://www.ptcruiserlinks.com/forum/...nt-dash-8.html
Or be sure to tell your locksmith everything that they need to know, and ask many questions so that you get the correct key for your car. ;)
ajhockey3 20 Jan 2019 03:37 pm
Re: Key replacement
If you happen to be in South Western ontairo Pop A lock is fantastic and comes to your door
RickinPA 20 Jan 2019 03:38 pm
Re: Key replacement
It's a little late, but...
The standard drill for chipped keys is when you have two, get a third. With two keys you can program the third key yourself, with your car, saving the dealer charge for programming a key.
If you only have one key, you can't program the new key with your car, you're stuck having the dealer program the new key ($$$).
rckstein 20 Jan 2019 03:54 pm
Re: Key replacement
That sounds like pretty good advice :good:
Found these on Amazon:
https://i.imgur.com/BaNY6D4l.jpg
https://www.amazon.com/KeylessOption...ler+PT+Cruiser
This is the programming procedure from the Owner's Manual:
https://i.imgur.com/pZ6gcigl.jpg
https://i.imgur.com/w1M7Zxul.jpg
That would be $15 well spent to have 2 extra keys just sitting around :D
But I don't remember getting the PIN when I purchased my vehicle. But the dealership should be able to provide that to me so I'll be sure to get that to also have on hand. ;)
PTloser32805 20 Jan 2019 04:57 pm
Re: Key replacement
I will order two keys from amazon today
rckstein 20 Jan 2019 05:04 pm
Re: Key replacement
Don't order the keys I posted, those are for the Gen2. ;)
What are you going to do about programming, you don't have 2 chipped keys?
PTloser32805 20 Jan 2019 06:24 pm
Re: Key replacement
Iíll order the correct keys, then check with a locksmith key guy if he can program from my vin number. If not Iíll pay a Mobil guy to program my keys
Unless thereís something I donít know about.....
rsrocket1 21 Jan 2019 09:17 am
Re: Key replacement
You need to fill out your profile with your location and year of mfr for your PT.
If you have a Gen 1, the Gen 2 key may not work.
Go to a Chrysler dealership with your vehicle registration and driver's license.
Get the key code and PIN from them.
It may save an extra $75 or so from the locksmith who may charge you to get the key code and PIN from Chrysler.
With the right locksmith and correct model keys in hand, you can get 2 keys cut and programmed for $50. One key cut and programmed for ~$100 is typical. $200-$250 from a dealership is common.
PTloser32805 21 Jan 2019 10:20 am
Re: Key replacement
I have a 2001, gen 1 car.
I used the search feature, is there a way to disable the security system so I can use my non chip key?
