Seat belt retractor connector removal
Like Tree2Likes
  • 2 Post By Plum01PT
Old 12 Feb 2019, 11:35 pm
Default Seat belt retractor connector removal
Hi all. I'm trying to remove the driver's side front seat belt retractor assembly
because it locked up and won't extend. I have two connectors on the
retractor; one for the seat belt light, the other for a charge port that activates
if you're in an accident. I cannot get the charge port connector off the
retractor. There is no lock clip on the plug and it won't pull out. I have factory
service manual and it mentions nothing special. I've seen others with a
locking clip like most automotive connectors have today. Picture attached. Any ideas?
Old 13 Feb 2019, 12:35 am
soonercruiser's Avatar
Default Re: Seat belt retractor connector removal
My guess would be (since the connection areas are round) that it might rotate to remove and tighten...much like headlight bulbs.
Frank, aka SOONERCRUISER,
Old 28 Feb 2019, 10:21 pm
Well, I found the answer . . . there are apparently a few years where the plug on the pretensioner is permanently connected to the seat belt assembly and uses a pigtail to the wire harness up inside the B pillar, which I didn't see until I tried to pull more wire out to figure out what was going on. Mine is a 2001. The seat belt assembly I bought was from a 2003. The auto salvage cross reference showed these fit 2001 - 2005 but that's not true as far as the pretensioner plug goes. Everything else was correct. I had to exchange it and they found a 2002 that fit. ARGH! That was driving me crazy!
rckstein and Cat22 like this.
Old 28 Feb 2019, 10:38 pm
rckstein's Avatar
Thanks for coming back to report the fix, could help someone else out in the future facing a similar situation.
09 Cruiser Head Removal w/o Timing Belt Removal boogeyman General PT Cruiser Discussions 16 23 Sep 2018 01:34 pm
Seat belt guides for non convertible seat swap brian2002utd PT Cruiser Convertible Forum 8 06 Sep 2018 05:51 pm
Air Bag light warning- Seatbelt Retractor Switch? moleary General PT Cruiser Discussions 0 12 Aug 2015 08:20 am
Seat Belt warnings etc. removal from sun visors RIGBY PT Cruiser Convertible Forum 3 15 Nov 2012 05:42 pm
Front seat removal Hvymtl General PT Cruiser Discussions 0 07 Sep 2011 01:35 pm
