Radio stops working related to ignition switch or key chip?
Like Tree4Likes
  • 1 Post By rcktpwrd
  • 2 Post By rckstein
Old 22 Feb 2019, 09:46 pm
Default Radio stops working related to ignition switch or key chip?
Hi all
My 04 PT's radio comes and goes intermittently, I was playing around tonight and found that the radio will work when key is in Acc. position but not work when car is running.
Has anyone see this before? Maybe something in the key chip? or ignition switch?
Thanks for your help
Jeff
Old 22 Feb 2019, 09:55 pm
rob302's Avatar
Default Re: Radio stops working related to ignition switch or key chip?
When the radio is out, does the horn work? If so I doubt its key related
Old 25 Feb 2019, 09:43 am
rcktpwrd's Avatar
Cool Re: Radio stops working related to ignition switch or key chip?
Is it just the radio display that is off or the radio doesn't actually turn on? If it is just the display, does the key in the ignition chime work? If the chime is also out then it is most likely a ground issue that is easily fixed.
Joel
www.rcktpwrd.com
Old 25 Feb 2019, 10:18 am
rcktpwrd's Avatar
Post #9 in this thread: radio fix
rckstein likes this.
Joel
www.rcktpwrd.com
Old 25 Feb 2019, 03:30 pm
The radio and horn are dead, When I banged on steering wheel radio and horn came back. Where is the ground for the horn/radio?
Seems like a loose ground someplace.
Thanks Jeff
Old 25 Feb 2019, 03:41 pm
rckstein's Avatar
Thanks Jeff
As previously posted:
Here are the pics from that thread:
Old 25 Feb 2019, 07:37 pm
rcktpwrd's Avatar
I did this repair back in 2011 based on my post in that thread, been working perfectly since then! Except for the horn... I added a separate button for that.
Joel
www.rcktpwrd.com
OEM CD/Radio to Ignition Switch problem harry General PT Cruiser Discussions 4 05 Feb 2018 09:14 am
Replaced ignition actuator switch, now radio display doesn't work Caelestis General PT Cruiser Discussions 11 19 Jun 2016 08:54 pm
Radio Not Working After Ignition Actuator Replacement jeremysaal Tech & Performance Forum 5 17 Nov 2015 02:09 pm
Ignition Switch / Random Stall / Loss of Radio - HELP DagnyT Tech & Performance Forum 11 31 May 2014 12:03 pm
Radio stops working when treble is moved ericraum General PT Cruiser Discussions 3 02 Jul 2004 05:57 pm
