Bought PT...150,000 miles...what should I have done to it?
Like Tree17Likes
Old 21 Mar 2019, 02:31 pm
shelbyzman's Avatar
Default Bought PT...150,000 miles...what should I have done to it?
I bought a 07 GT (5-speed) that has 150,000 miles. It is already having some shifting problems.....so, since I don't know what all has been done to it, I'm having my mechanic/cousin go ahead and change the timing belt, water pump & tensionor, serpentine belt, and possibly the center motor mount. Is there any other "preventative" maintenance I should him to do while he has it?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 21 Mar 2019, 02:47 pm
Default Re: Bought PT...150,000 miles...what should I have done to it?
Do the PCV valve. Its a cheap item. Mine dissolved while driving and I hat to remove the Valve cover to get all parts out
And of course the usual suspects:
- oil+filter
- brake fluid
- gas and air filters
- coolant (maybe thermostat while system is drained - guess it already will be for the timing belt job)
Further, check spark plugs, lines and the ignition module. Then you should be good to go.
Old 21 Mar 2019, 02:57 pm
shelbyzman's Avatar
- oil+filter
- brake fluid
Thanks for the info!
Old 21 Mar 2019, 03:03 pm
Having a third key made now is a lot cheaper than a second if you lose one.
A month after replacing the timing belt/water pump on my brothers cruiser the water pump inlet tube started leaking (easy fix). My brother thought it was the water pump and was going to junk the car.
rockandroller likes this.
Old 21 Mar 2019, 03:04 pm
rcktpwrd's Avatar
Cool Re: Bought PT...150,000 miles...what should I have done to it?
I would also change the transmission oil/fluid.
I don't think any PT's have a replaceable fuel filter, I think it is part of the pump and sending unit assembly.
Joel
www.rcktpwrd.com
Old 21 Mar 2019, 03:09 pm
shelbyzman's Avatar
good ideas!
Old 21 Mar 2019, 03:33 pm
Since it will be all apart anyway, make sure he replaces the crank seal and the two cam seals. If they begin leaking down the road, it could mean basically doing the timing belt job a second time for $10 worth of seals. Also, this is the time to inspect and replace the middle motor mount too.
Old 21 Mar 2019, 05:39 pm
My02RedRide's Avatar
With those miles I would take a look at the shifter bushings. My '02 5 speed with 120K they fell apart at the shifter end. Bought BUGGER BUSHINGS to replace all 4 like I did on my 98 Neon R/T and what a difference. Nice and tight now.
Look over suspension especially the front lower control arms rear vertical bushings for sag / debond… see anything unusual replace the arms.
2002 PT 4 door Inferno Red
2008 PT Convertible Bright Silver
Old 22 Mar 2019, 09:32 am
SpaceMouse's Avatar
What myckee said- change out all the hard-to-access stuff that's exposed while you've got the timing belt covers off. You may end up kicking yourself repeatedly if you don't.
Old 22 Mar 2019, 10:07 am
shelbyzman's Avatar
Thanks for the help everyone! I have mentioned this stuff to my cousin....hoping to get my PT back and ready to go for another 100,000
Bought 04 PT Cruiser limited w/turbo and high miles, lots of negative comments califolkscruzin General PT Cruiser Discussions 33 05 Mar 2015 03:42 pm
I just bought a 04, what do I need to know? 32seventeen Welcome New PT Cruiser Members 20 07 Jun 2012 08:14 pm
Bought another PT! morrises General PT Cruiser Discussions 2 14 Dec 2008 09:59 pm
Just Bought a PT Seaspark General PT Cruiser Discussions 10 16 Feb 2008 05:02 pm
Bought my new PT under 48 hrs ago chubsiewhubsie General PT Cruiser Discussions 19 13 Sep 2007 07:09 pm
