Turn signal problem
Like Tree3Likes
  • 1 Post By circus
  • 1 Post By RickinPA
  • 1 Post By ptcruisersteve
Old 27 Mar 2019, 11:14 pm
Default Turn signal problem
I have a 2003 PT Cruiser Limited. The passenger (right) side blinker (front and rear) does not work, even when using hazard flashers. Sometimes, when I turn the right turn signal on, the driving lights will come on. If I’m just changing lanes, the right turn signal will not work, but it will not cause the driving lights to come on either.
Both bulbs are good. Is there anything else I should check before changing the multi-function / turn signal switch?
Thanks,
Dan-O
Dan-O
2006 PT Cruiser Limited 2.4 N/A, 5 speed, purchased with 77K miles, rear splash guards, Mopar subwoofer, rear bumper guard
2003 PT Cruiser “Woody” Limited 2.4 N/A, automatic transmission, bequeathed to me with 62,500 miles, rear splash guards, Mopar subwoofer, rear bumper guard
Old 28 Mar 2019, 06:06 am
Default Re: Turn signal problem
Check grounds. Often several circuits share a common ground. When the ground is poor, electricity can flow down one wire then back up another. Weird things then happen.
kirbo7106 likes this.
Old 28 Mar 2019, 06:20 pm
I don't have anything to suggest, but I'll say the multifunction switch is a bit troublesome. The good news is they aren't too expensive and are easy to replace.
I've got an '01 PT (original owner) and am on my second replacement multifunction switch. It usually seems to be some issue that includes the fog lights.
If you search "multifunction" you'll get a lot of hits, including how to replace guides.
Good Luck.
Old 28 Mar 2019, 07:49 pm
I would suggest checking the wires behind the light bulb sockets. Some members have had wires sheared off after pulling the light bulb sockets out a few times. Check both front and rear sockets.
07 turn signal problem Chucky General PT Cruiser Discussions 2 03 Sep 2017 06:09 am
Turn Signal Problem Larry2828 General PT Cruiser Discussions 8 12 Nov 2014 01:04 am
Turn signal problem Karenscruiser Tech & Performance Forum 2 12 Jun 2012 02:12 am
2005 turn signal problem ricksterw General PT Cruiser Discussions 7 18 Feb 2010 05:59 pm
Turn Signal Fuse Problem Indynick General PT Cruiser Discussions 1 04 Jul 2004 07:33 pm
