Engine has rod knock
Like Tree14Likes
Old 02 Apr 2019, 04:28 pm
Goonior's Avatar
Default Engine has rod knock
Was on my way home from Wisconsin Sunday night when I noticed a knocking sound getting louder and louder. I stopped and checked the oil, two quarts low!!! Filled it back up but it was still knocking very loud, oil light never came on.
I had no choice but to keep driving another 70 miles to get home. I will check this weekend to see if it can be saved or if it's done for. Meanwhile I get to drive my dad's 2008 300 Heritage Edition until I figure out what do.
2004 N/A auto. Touring Edition (Died 2016 resurrected Nov 2017) bought for $100 Oct 2017 w/122k mi, died March 2019 143K mi, engine replaced with 2004 w/ 71K in October 2019. Added RBQ 6-disc changer w/Sirius. Replaced TB,WP, thermostat and gasket, front bearings w/one hub, ceramic pads w/new rotors, one brake caliper w/bracket, and lower control arm. More changes/repairs as the weather allows .
1999 300M 196k mi (now her daily driver)
"The most terrifying words in the English language are: I'm from the government and I'm here to help." Ronald Reagan
Old 03 Apr 2019, 07:42 am
Default Re: Engine has rod knock
Ehhhhh, it's a 15 year old vehicle. I'd suggest you check the oil once a week. Hell, my car isn't even 2 years old yet and I check it weekly. Just a habit I picked up from my Dad as a kid growing up in the 70's, I guess.
Old 03 Apr 2019, 08:30 pm
_PTGT03's Avatar
drive it until the engine seizes, and then get another $1000 car. not worth fixing.
did you take the car to a mechanic to make sure it's an internal engine problem and not something else
Old 04 Apr 2019, 03:25 pm
Goonior's got a goner. Fifteen years ago my freebee Supreme had a bad cam. Had a bunch of miles so I decided just to replace the whole engine. $325 and 1/3 the miles. Couldn't have replaced the cam for that. Still is my good car and doesn't use any oil.
Car-Part.com--Used Auto Parts Market
Old 05 Apr 2019, 03:04 pm
chris15's Avatar
FWIW, the oil pressure indicator lights on these cars are a joke. By the time they legitimately indicate an oil pressure problem, you've likely already done irreparable damage to your bearings. Luckily, I'd say ~99% of all "my oil pressure light is on" cases with PTs simply indicate that the oil pressure switch is faulty and needs replacing.
2003 GT (6262, the works)
2001 PT MTX-Swapped/Turbo
Old 05 Apr 2019, 06:59 pm
Yepper!
Jerry
Old 05 Apr 2019, 09:02 pm
I have read this about the oil light before pertaining to the PT Cruiser. There is no substance to any reasonable facts about the previous comment and also looking at the any PT Cruiser wire diagram it is also unreasonable. LOL
One thing that most that modded a PT cruiser know well is that the oil pump was actually to much for the 2.4 and Chrysler had to even use a restriction in later block to limit oil going to the head.
So if what was said true about the oil light not only would you hear tappet noise long before any remaining oil would cause "black death" of any crank or rod bearing most would have the common sence (you would think???) to shut off the engine.
Old 05 Apr 2019, 09:04 pm
Originally Posted by wwpptc View Post
Yepper!
Jerry
Jerry I am sure the shop guys at that shop you use to visit and work at would tend to agree with my last comment as you would if you worked on enough 2.4 Chrysler engines??? Maybe not? FYI I talked to them a few times.
chuzz likes this.
Old 15 Apr 2019, 06:59 pm
Goonior's Avatar
Just to let everyone know. I started it "ONE LAST TIME" to move it up about 10 feet and the rod let loose. The engine is, at this time, a boat anchor . I am still undecided about what I want to do at this point. I may try to rebuild it or get another engine for it IDK. The weather is finally starting to improve in Chicago and now that I have a new job where I will have afternoons (working 6am to 230pm), weekends free and making more money to boot I may pull this thing and see how much damage, if any, may have been done to the block. I know a lot of you out there may feel it's not worth it, but at the same time I feel a responsibility to treat this one right after the rough life it's had so far.
rockandroller likes this.
Old 15 Apr 2019, 07:51 pm
_PTGT03's Avatar
it makes more sense to dump your car and get another identical model with lower miles and that has been well cared for. you would save time, effort, money and come out ahead with a parts car.
Getting a bad engine knock Toolman General PT Cruiser Discussions 6 22 Aug 2016 09:04 am
2006 PT Engine Knock..Like New Vehicle mlshermancpa General PT Cruiser Discussions 17 06 Jul 2013 11:49 pm
engine knock new car well new to me anyway jeep1981 General PT Cruiser Discussions 6 29 Sep 2011 02:52 pm
Engine vibration / suspension knock Jassy Tech & Performance Forum 6 09 Apr 2011 02:23 am
2.4L NA Engine Knock DIYPTGUY Tech & Performance Forum 4 22 Jul 2009 01:44 pm
