Upper Motor Mount help needed
Old 11 Apr 2019, 08:40 am
shelbyzman's Avatar
Default Upper Motor Mount help needed
My cousin is working on my pt and mentioned that I need a new upper motor mount. My question is, what is the replacement part #? I am finding several different mounts on RockAuto and some of them don't even look the same. My PT is a GT with a manual trans. Are autos and 5 speed mounts any different? Also, the black part in the middle...does that have to be replaced as well (red/arrow see pic)? The mopar part is over $100 and I am already looking at about $1500 in repairs to my pt and am trying save any cash I can. Any help would be appreciate because I need to get this part ordered asap.
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 11 Apr 2019, 09:38 am
SpaceMouse's Avatar
Default Re: Upper Motor Mount help needed
Not sure about the auto vs manual differences, if any, but the black part in your photo is what the mount connects to, and doesn't need to be replaced. What goes bad on the mount is the big round rubber bushing which dries out and cracks, allowing the engine to move more than it should.
Old 11 Apr 2019, 09:48 am
shelbyzman's Avatar
Thanks for the info.....I have read that Mopar is the best way to go with motor mounts...they are so freaking expensive though, lol. I don't want a crappy replacement that won't last though either. I can't find any info if the manual has a different mount other than on ebay listing that says "automatic only".
Old 11 Apr 2019, 10:03 am
shelbyzman's Avatar
I guess I will bite the bullet and get the mopar mount - # MOPAR 5085122AB. This appears to be the correct part for the manual trans. Around $100 and non oem are about $10 but are probably crap
Old 11 Apr 2019, 07:38 pm
I got mopar upper and lower mounts. Still good with 45,000 miles on them. I agree they are expensive. Be careful not to pull on the A/C lines removing and installing the new upper torque mount. I used cardboard tto keep the A/C lines from being damaged.
Don't forget to do the 4.720 alignment or you will be replacing the mounts again.
Old 11 Apr 2019, 08:14 pm
ajhockey3's Avatar
Originally Posted by ptcruisersteve View Post
Don't forget to do the 4.700 alignment or you will be replacing the mounts again.
what?
2006 PT Cruiser Base 2.4L NA $250
Old 11 Apr 2019, 08:31 pm
Originally Posted by ajhockey3 View Post
what?
Help with replacing Lower and Upper Torque Struts
Old 12 Apr 2019, 08:48 am
shelbyzman's Avatar
Thanks for the info. Is the 4.720 alignment in the service manual? That is probably what my cousin is going by.
Old 12 Apr 2019, 11:18 am
rsrocket1's Avatar
what?
119mm = 4.72" from the rear bolt hole of the removable bracket to the hole in the bracket that the rear of the torqe strut bolts onto.
If you buy them at Rock Auto, they are less than $10 each. You could buy 10 and still be ahead of what Mopar charges for them.
Autozone charges about 4x what Rock Auto does but they have a lifetime warranty so when it wears out, bring it in and they'll give you another one so 4 replacements is right around the break even point. Replacing and aligning them takes about a half hour so it's not a big deal either way.
Upper Motor Mount Replacement Help brentcsi101 Tech & Performance Forum 2 07 Jan 2014 09:45 pm
03 Touring Ed. upper motor mount replacement dadjmon Tech & Performance Forum 1 22 Sep 2011 11:31 am
how to replace your upper motor mount pppt03turbo Tech & Performance Forum 0 12 Sep 2011 07:51 pm
Motor Mount (upper strut) bolts. mdfrodolives Tech & Performance Forum 12 07 May 2011 02:12 am
Upper Motor Mount Issue Mathias Tech & Performance Forum 6 22 Sep 2010 01:24 am
