how to remove center motor mount
Old 26 Apr 2019, 09:01 am
Default how to remove center motor mount
I have a 2006 pt that the hex t55 bolt has broken. How do I remove the bracket and center motor mount as there is very little space in the area. I welcome suggestions, thank you very much for your help and assistance
Old 26 Apr 2019, 10:07 am
Default Re: how to remove center motor mount
Do a search here for timing belt replacement. That's what you have to do in order to replace the center mount. Terrible design. If you have a lot of miles on your PT, you might as well do the timing belt and water pump while you're at it. Along with the cam and crank seals. Do it all at once and you're good for another 100,000 miles.
Center Motor Mount Replacement? rckstein General PT Cruiser Discussions 2 28 Aug 2015 09:32 pm
How do you remove the mid motor mount bracket? Flash619 General PT Cruiser Discussions 1 02 Apr 2015 07:57 pm
How to remove upper motor mount video Kawizx9r Tech & Performance Forum 30 20 Jun 2012 03:28 pm
02 PT center motor mount Brandon12 Tech & Performance Forum 6 16 Oct 2011 10:06 pm
Center Motor Mount Replacement jjackson23 Tech & Performance Forum 2 25 Jun 2011 12:20 pm
