No Start After Timing Belt
Like Tree3Likes
  • 1 Post By ptcruisersteve
  • 1 Post By pt06
Old 26 Apr 2019, 04:27 pm
Default No Start After Timing Belt
I have read a multitude of the threads covering this problem, but I have yet to find my solution:
2001 PT Cruiser (non turbo) 2.4L
Sister driving it down the interstate, something flew up into it and crushed the water pump gear. Timing belt remained sort-of on, but obviously jumped teeth.
Tore down the PT, installed new water pump and timing belt.
Wouldn't start - cranks and seems to fire on a couple cylinders, but won't go all the way.
Looked at timing again, it was off a bit. So I redid the timing -- 6 times.
This last time, the timing seems to be dead-on, and even after trying to start and rotating crank manually, everything remains aligned (crank and cams).
I can sit there and hold the key in ignition and it kind of tries to start, you think its going to catch, a few cylinders fire and the muffler poofs out some white smoke, but then it just dies off and after a moment will do the same again...
Any thoughts, what to check/attempt next?
Old 26 Apr 2019, 06:13 pm
Default Re: No Start After Timing Belt
The camshaft sensor and coil plug get switched as they are the same. Check to make sure they are connected properly.
Handy_Cruiser likes this.
Old 30 Apr 2019, 06:53 pm
I never had to unplug the cam sensor for the timing belt work...
I did see where people said try unplugging the cam sensor and then see if the car will start.. tried that, but then the battery died so not sure yet. Is this a real technique?
Also, I hear that its a non-interfering engine so the pistons won't interfere with valves, but is the cams are way out they can mess with eachother??? The cams were way out of time with eachother.
THANKS!
Old 30 Apr 2019, 08:21 pm
I would suggest first checking the engine compression in all cylinders. Post what you find.
chuzz likes this.
Old 03 May 2019, 04:53 am
Check the wiring harness near the passenger axle shaft for damage.
Tags
timing belt
About to start timing belt job! fisheyestudio Tech & Performance Forum 5 22 Jul 2016 01:13 pm
Timing Belt Changed and now will not start - HELP rhowle Tech & Performance Forum 3 18 Mar 2012 08:59 pm
After timing belt wont start moparman75 Tech & Performance Forum 1 17 Apr 2011 10:39 am
timing belt/ no start/ no compression sylster General Turbo Discussions 8 01 Mar 2010 08:42 pm
timing belt no start YouPutz Tech & Performance Forum 17 27 Feb 2010 04:38 am
