Window Glass Interchangeability?
Old 30 Apr 2019, 09:45 pm
SpaceMouse's Avatar
Default Window Glass Interchangeability?
So I did this with a weed whacker:
My local Pick 'n' Pull has a dozen 2001-2005 PTs, and mine is a 2006. Is there a difference in the shape, mechanism, or anything else that would prevent me from using an earlier model window?
Old 01 May 2019, 07:12 am
Handy_Cruiser's Avatar
Default Re: Window Glass Interchangeability?
There was a mechanism change but I believe it was between 2002 and 2003. I'm not sure if that affected the glass or not. A salvage yard should have an interchange/application guide. You can check with one of them. Also, you appear to have the factory tinted glass. Or is that window film? A lot of PT's don't have tinted glass so you will need to specify whether you have it or not and/or look for the right one if pulling your own.
DRIVER LEFT QUARTER GLASS WINDOW replacement LM3 General PT Cruiser Discussions 3 10 Sep 2016 05:19 am
Rear window glass without wiper hole? NMdesertracer General PT Cruiser Discussions 1 04 Apr 2009 07:54 pm
Seeking 2002 LTD glass/window specs & replacement adivce j3s General PT Cruiser Discussions 1 23 Feb 2009 02:01 am
port window glass on back door needed! charlieincrew Vendors & Buyers Forum 3 28 Dec 2008 03:28 pm
R&R the rear window glass? Cal Cruzer General PT Cruiser Discussions 3 18 Nov 2004 12:26 am
