What arrow direction for catch can?
Like Tree3Likes
Old 01 May 2019, 08:39 am
shelbyzman's Avatar
Default What arrow direction for catch can?
I have a 07 GT and installed a K&N style air intake. My question is: I have the hose that used to go to the air intake but am diverting it because I don't want oil etc going up into the turbo. So, I am adding a catch can with a filter at the end of it. I need to know what direction the air flow needs to go (arrow on catch can). Does it go out toward the little filter or in towards the engine?
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 01 May 2019, 10:03 am
soonercruiser's Avatar
Default Re: What arrow direction for catch can?
I've got a catch can on my Dodge Challenger SRT8 HEMI.
(Known for considerable Blow-By....about a half can per oil change.)
But, I've never seen a discussion about a catch can on a PT GT!
Didn't think that we have THAT MUCH blow by to be concerned about.
Frank, aka SOONERCRUISER,
Old 01 May 2019, 10:24 am
shelbyzman's Avatar
As I understand it, the reasoning is that with a turbo car, you don't want oil or anything else going to the turbo since the air intake goes to the turbo and not the throttle body like a n/a engine
Old 01 May 2019, 10:31 am
Handy_Cruiser's Avatar
Flow should go toward the intake manifold. That's the way it works most of the time. But it reverses when the throttle is open and when under boost. If you have have a boost gauge, you can watch this in real time as pressure goes from negative to positive in the intake manifold.
Ideally, the positive pressure from boost is prevented from entering the crank case by the PCV valve. However, it doesn't seem to work all the time. That's why I recommended an extra check valve between the PCV valve and the intake manifold. But even with this all working correctly, there will be no negative pressure on the crank case during open throttle and/or boost. So at that time, any blow-by can create positive pressure on the crank case and freely escape through the PCV vent instead of being scavenged back into the intake manifold. That's where the oil comes from. Blow-by is mostly water vapor gas and oil particulates. The water vapor often evaporates away but the oil remains.
PS: In the type of catch cans used on modern Hemi engines, they remain cool enough for water to collect in them. When I dump mine, I often find a water layer and an oil layer. While most Hemi's are naturally aspirated, the design appears to create blow-by even in new engines. Chrysler put an elaborate PCV system in the intake manifold, but a catch can is still a good idea. I often collect half a cup of oil between oil changes.
Old 01 May 2019, 10:37 am
shelbyzman's Avatar
I had the arrow going out to the little filter (the end where the hose used to connect to the airbox) So, I need to switch it? If so, do you think it could have messed anything up driving with it like this for the last couple of days?
Old 01 May 2019, 10:45 am
I doubt you messed anything up. I don't know which catch can you are using, but it was likely just less efficient. In many, the blow-by enters the can from the side or near the bottom while the air leaves the cap from near the top. You may want to rinse out the wire mesh filter in the catch can if it has one. This can often be done with WD40.
Old 01 May 2019, 10:54 am
shelbyzman's Avatar
I doubt you messed anything up. I don't know which catch can you are using, but it was likely just less efficient. In many the blow-by enters the can from the side or near the bottom while the air leaves the cap from near the top.
Good to know. This is what I'm using: https://www.ebay.com/itm/New-Engine-...8AAOSw1lxcfztM
Handy_Cruiser likes this.
Old 01 May 2019, 03:08 pm
Fk5 Fk5 is offline
I don't think you have your catch can in the right line. The "make-up" air hose (driver's side of valve cover) to air box does not need a catch can. If you vented it to atmosphere and put a filter, what are you preventing from entering your turbo? The catch can @Handy is talking about goes in the PCV valve (passenger side of valve cover) to intake manifold line.
I almost posted this in the thread with your initial question, but it appeared that @Handy had explained it well enough. I guess he didn't.
2003 GT 5 speed
162,000 miles
Old 01 May 2019, 03:23 pm
shelbyzman's Avatar
I thought the reason for the catch can is so that you don't have to clean out the little filter coming of the line that used to go to the stock air box since the catch can is "catching" the oil. Either way, I want to make sure I have the direction/flow of the catch can correct.
Old 01 May 2019, 03:33 pm
You should be asking the manufacture,reading the instructions for installation or contact and ask the supplier you purchased it from.
Fk5 likes this.
inserted key wont key in any direction butterfly_pt_01 Tech & Performance Forum 12 18 Nov 2013 11:10 pm
cooling fan direction gotell56 General PT Cruiser Discussions 3 01 Nov 2013 01:29 am
Direction Problem in 02 Latux87 Interior Accessories Forum 1 22 Aug 2013 09:23 am
need to be pointed in the right direction... honu Turbo Performance 6 27 Nov 2011 05:36 pm
Need some direction bluefalcon1 Tech & Performance Forum 1 15 Nov 2008 05:02 pm
