AC has charge but air still not very cold
  • 1 Post By NitroPT
Old 04 May 2019, 05:20 pm
Default AC has charge but air still not very cold
I searched the forum but no luck on this, I have a 05 non turbo and I tried to add coolant to the AC and the gage said it was charged. It blows cool not cold air any ideas where to look for issues? My mechanic wante $150 just to inspect the system which sounds crazy to me. The compressor seems to be kicking on and off (hard to see it)
Thanks all
Jeff
Old 05 May 2019, 09:49 am
Handy_Cruiser's Avatar
Default Re: AC has charge but air still not very cold
First, make sure your radiator fan is running on high when the AC is on. If there no air blowing across the condenser, that can cause the compressor to cycle off and on due to high low-side pressure. If the radiator fan is running on high, pull the the center dash console and follow the mix cable back to the mix damper to make sure it's working and shifting all the way to the cold side.
Old 05 May 2019, 11:55 am
The labor charge is fair if they have an AC recycle machine that will do a pressure test recover the Freon and replace the Freon in the correct amounts.
There could be numerous reasons why you may feel the less then cooler AC? We would need to know the temperature coming from the AC on MAX and compare it to the ambient.
A simple 5 dollar temperatures gauge at the grocery store to measure cooking temperatures works well for this.
WARNING: DO NOT try to add more Freon until you know what the problem is!
chuzz likes this.
Old 06 May 2019, 11:08 am
VsandFords's Avatar
The temp selector knob on the dash may not be working properly. Possibly a problem with the selector door under the dash moving from hot to cold.
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
No charge Hostilgtkb Tech & Performance Forum 1 17 Jul 2013 12:09 pm
2006 AC charge samss Tech & Performance Forum 4 03 Jul 2013 11:14 pm
Turbo Charge? dzyubin Tech & Performance Forum 12 06 Oct 2011 09:57 pm
A/C Re-Charge price? edj8 General PT Cruiser Discussions 6 26 Jun 2010 09:34 pm
