Purge solenoid question.
Old 07 May 2019, 07:20 pm
Default Purge solenoid question.
Replaced the solenoid and didn't mark the hose orientation! Dumb!
There are only two, 50/50 chance right? I don't see any markings on the solenoid. Does it matter which hose goes on which nipple and if so how do you know which one goes where!
Checked the service manual and several online sources and they don't mention hose placement.
Thanks
Old 07 May 2019, 07:41 pm
_PTGT03's Avatar
Default Re: Purge solenoid question.
i don't think it matters. a solenoid opens and closes a path for fluid to flow. a check valve would matter the direction.
2006 Touring/2.4l/convertible-Purge Solenoid Deac1234 General PT Cruiser Discussions 15 11 Oct 2018 06:29 pm
Please help--need to replace the purge valve solenoid! mbindy Tech & Performance Forum 4 09 Nov 2014 12:42 pm
Purge Valve Solenoid mbindy Tech & Performance Forum 0 06 Oct 2012 01:26 pm
2002 PT cruiser SE Solenoid question icewayne121 General PT Cruiser Discussions 15 22 Dec 2009 07:57 pm
Purge solenoid elmeyer Tech & Performance Forum 0 19 Aug 2009 07:14 pm
