replacement PCV valve not right position
  • 1 Post By shelbyzman
Old 08 May 2019, 03:51 pm
shelbyzman's Avatar
Default replacement PCV valve not right position
I was going to change the PCV valve on my 2007 PT Cruiser GT. But when I go to turn it to mount it it's at the wrong angle for the hose. It's off by about 15 to 20 degrees. Anyone else have this issue? The part number is the same and it looks like the same PCV valve.
2007 PT Cruiser GT 5-speed 17x8 Konig Inception wheels K&N style intake auto throttle body Spec D tail lights Blow off plate 10.2mm plug wires Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack "blacked out" DIY ground effects added boost gauge (in place of analog clock)
Old 09 May 2019, 05:06 pm
Fk5 Fk5 is offline
Default Re: replacement PCV valve not right position
IIRC, the top part rotates. I'd be careful and wait to chime in because that is how I cracked my original.
2003 GT 5 speed
162,000 miles
Old 09 May 2019, 06:59 pm
Handy_Cruiser's Avatar
Many of the replacement PCV valves for the turbo PT's are made in two pieces. As mentioned, you can usually rotate the top part in the plastic sleeve.
Old 10 May 2019, 12:40 pm
shelbyzman's Avatar
Unfortunately this one doesn't rotate. It looks exactly the same as the stock one...the grooves, everything. But when it twists it gets tight at a different angle. Doesn't make sense to me as it looks the same.
Old 10 May 2019, 01:34 pm
Fk5 Fk5 is offline
That picture doesn't show me that it doesn't rotate. You'd have to see it from the top. Even if it doesn't, you should have 2 angles you can put it at - Keep track of how you start it. If you don't like the angle, try putting it in 180 different and it will probably end up 180 degree different, which might be useable. Like the oil cap, you should be able to put it in the opposite way.
2003 GT 5 speed
162,000 miles
Old 10 May 2019, 02:10 pm
shelbyzman's Avatar
I did try it at the two different angles...one is about 15 degrees off, the other is the total opposite direction. I will mess with it again and see if I can start it at a little different angle.
Old 11 May 2019, 07:26 am
What about using a slightly longer piece of hose?
Old 11 May 2019, 07:18 pm
shelbyzman's Avatar
The angle of the hose isn't exactly right but I was able to get it to fit on. Should be good to go. Still not sure why the angle is still off a little bit
Handy_Cruiser likes this.
Crankshaft position sensor replacement Vic Feedback and Support 3 25 Oct 2015 06:50 pm
PCV Valve Replacement Assistance Please sjp5054 Tech & Performance Forum 4 30 Aug 2015 08:25 pm
PCV Valve Replacement PTCruiserGal Tech & Performance Forum 25 12 Apr 2014 09:23 am
PCV Valve Replacement. mdfrodolives Tech & Performance Forum 3 10 Jul 2011 10:30 pm
P0340 Camshaft Position Sensor replacement '07 TurboLite crooozin Tech & Performance Forum 0 02 Mar 2011 03:39 pm
