Parking Brake Adjustment
Old 09 May 2019, 08:43 am
shelbyzman's Avatar
Default Parking Brake Adjustment
My parking brake only works if I pull the level all the way back. I need to adjust it but when I jacked up the back and took the little rubber grommet off it just looks like a spring and not "notches" to use a screwdriver to adjust. It's a turbo with disc brakes all around. I really don't want to have to take the console out to adjust it there....any ideas? I may take a better look at it and see if I can figure it out (didn't have much light when I checked it).
2007 PT Cruiser GT • 5-speed • 17x8 Konig Inception wheels • K&N style intake • auto throttle body • Spec D tail lights • Blow off plate • 10.2mm plug wires • Cat-Back "DNA Motoring" exhaust w/ Thrush glasspack • "blacked out" • DIY ground effects • added boost gauge (in place of analog clock)
Old 09 May 2019, 03:24 pm
Default Re: Parking Brake Adjustment
The adjuster is in front of the spring, I find it easiest to shine a torch up close and look from behind from a bit of a distance but if you can see the spring ok you are almost there.
Old 09 May 2019, 03:57 pm
shelbyzman's Avatar
Thanks! I am going to try again, lol
DIY parking brake fallout Lanerious General PT Cruiser Discussions 18 13 Apr 2017 12:40 pm
Parking brake shoes Jassy Tech & Performance Forum 21 18 Jan 2015 02:17 pm
Parking Brake/Brake Dash Light PhxPT Tech & Performance Forum 4 24 Jan 2013 08:41 am
parking brake stevas Tech & Performance Forum 1 04 Jan 2011 11:47 am
Drum brake replacement Parking brake cable Dorkygrin General PT Cruiser Discussions 2 28 Mar 2009 07:53 pm
