No voltage at Impact sensor
Old 10 May 2019, 07:41 pm
Default No voltage at Impact sensor
Airbag light on. Code is titled "Lack of Communication with right front impact sensor". Replaced sensor. No joy. Checked for power at sensor. No power. Voltage for this sensor comes from module under console. Is it a big job to remove console?
Anyone ever had this problem before?
Old 11 May 2019, 07:15 am
Default Re: No voltage at Impact sensor
While removing the console is somewhat a chore, it's not too bad. Just remove both arm rests off the seats before you try to pull it out. That makes the job a LOT easier.
Old 11 May 2019, 08:53 am
ptprice's Avatar
The center console came out while we did some air conditioner work on SOOO BIG a while ago. Although that photo series was dedicated to A/C work, maybe you can spot that plug assembly in these two photos showing the center floor in the back ground.
Happy PTin', ptprice
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 11 May 2019, 11:07 am
Could be wiring. I had a recurring problem with a throttle positioning sensor in a Dodge Neon. In the end, I ohmed out the wires between the TPS and PCM. One of the wires had very high resistance, it was broken somewhere in the wiring loom. I spliced in another wire, jumping the bad portion, and that fixed the problem.
No voltage at Impact sensor gdmclnh General PT Cruiser Discussions 0 10 May 2019 07:35 pm
front impact sensor guitarman Tech & Performance Forum 7 06 Jun 2013 08:13 am
How to change the right front impact sensor? wvladimire General PT Cruiser Discussions 5 19 Jul 2012 11:09 pm
P0123 Throttle Position (TP) Sensor Circuit High Voltage stan6406 Tech & Performance Forum 5 22 Feb 2012 07:30 pm
P0452 Fuel Tank Pressure Sensor Circuit Low Voltage dornstar General PT Cruiser Discussions 0 22 Aug 2007 12:05 am
