Rough idle and vibration through car in reverse at 0mph. Smooth when moving
Old 25 May 2019, 08:23 pm
Default Rough idle and vibration through car in reverse at 0mph. Smooth when moving
Hey all
2006 na pt cruiser base
The car is relatively smooth in park and neutral. As soon as I put it into reverse or drive, the idle becomes rough. Especially if it is reverse. I also start I hear a spinning loud noise in the engine by the passenger side (serpentine belt?)
Things replaced
Timing belt
3 motor mounts (does this include transmission mount?
Wires
Spark plugs
Oil
Filters
Pcv valve.
Fluids are all full and don't seem to be leaking.
Serpentine belt? Would a video recording help?
--2006 pt cruiser non turbo owner. Completely stock... For now.
Old 25 May 2019, 08:53 pm
LionPT's Avatar
Default Re: Rough idle and vibration through car in reverse at 0mph. Smooth when moving
Originally Posted by funkyfred View Post
Hey all
Things replaced
Timing belt
Wires
Spark plugs
Oil
Filters
Pcv valve.
What is the RPM in Park, what is RPM in Drive..??
A/C on or off..??
Any codes..??
Check O2 Sensors & wires.
Old 25 May 2019, 08:57 pm
A/C on or off..??
Any codes..??
Park = 750
Reverse=800 ( start to hear grinding / sputtering in engine at idle. Goes away when I release brake pedal. Seems like only idle causes it)
Drive = 750 rpm and no noise
Ac on
Park=700
Reverse 750-800 revs go back and forth
700rpm
No codes
How do I check o2?
Old 25 May 2019, 08:58 pm
Is the transmission mount different than the motor mount(big 3?) I had 3 mounts replaced when I had timing belt done.
Old 25 May 2019, 08:59 pm
A/C on or off..??
Any codes..??
Which wires? Spark plugs wires? They are new
Old 25 May 2019, 09:33 pm
Was the motor mount 4.720 dim alignment done for the upper and lower torque mounts?
Old 25 May 2019, 09:59 pm
Done by an indepent mechanic that is not all perfectly familiar with pt cruisers. Reverse seemed somewhat tight and improved right after it was done. Now it feels worse than before.
Is it replace the engine Mounts again correctly or just live with it?
Old 26 May 2019, 07:51 am
There are four "motor mounts".
What supports the engine/transmission are two mounts. One mount is at the timing belt end of the engine. When a timing belt is replaced, this mount has to be disconnected from the engine, so it is often replaced as a proactive measure. The other mount is at the far end of the transmission. These two mounts support the engine/transmission.
The other two mounts are torque struts. There's one at the top near the timing belt cover, you can see it when you lift the hood. The other torque strut is on the bottom side of the engine pretty much directly below the upper torque strut. The torque struts do not support the engine. Torque struts control the torque of the engine/transmission, keeping the engine in place when under load. A symptom of a bad torque strut is the engine rocking excessively when placed into gear.
All mounts have rubber to isolate vibration. All mounts have to be installed with correct alignment, there's adjustment in the mounting holes (slots).
Old 26 May 2019, 12:59 pm
If you don't want to have to replace your motor mounts I would take it back and have the mechanic check the 4.720 alignment to make sure the motor mounts are not being damaged as you are driving the Pt Cruiser.
Old 26 May 2019, 03:17 pm
ajhockey3's Avatar
It wasn't just reverse but I was having a rough idle and the car stalled on me if sat for awhile in drive and stalled often in reverse, I cleaned the MAF sensor in about a minute and popped it back in and its been doing great!
2006 PT Cruiser Base 2.4L NA $250
Rough Feeling Around 40mph, Pedal Vibration/Wheel Vibration Flash619 General PT Cruiser Discussions 6 12 Aug 2017 01:14 pm
Idle not smooth kshanok Tech & Performance Forum 63 12 Jun 2015 08:52 pm
PT Cruiser smooth idle rough when you accelerate quickly. DollarIcedTea Tech & Performance Forum 4 21 Jan 2014 08:33 pm
after oil change, rough idle first, smooth out later edb General PT Cruiser Discussions 8 14 Feb 2011 04:40 pm
vibration in reverse EddieJR666 PT Cruiser Convertible Forum 0 24 Nov 2004 02:41 am
