keeps overheating
Like Tree3Likes
Old 27 May 2019, 09:17 am
Default keeps overheating
ive got a 2003 pt non turbo .its an automatic car has 90k miles. ive replaced radiator(car had accident damage) water pump and timing belt, thermostat, upper lower radiator hoses, heater core hoses, flushed heater core real good. no coolant loss, no burning smell of it,no visible loss, no bubbles in the filler neck. car over heats. car runs real good. no miss or check engine light. im at a loss here. there was alot of rust/ scale built up in the cooling system and ive changed the collant since last time it over heated as the coolant turned a poop brown from the rust. its alot cleaner now, but still gets hot.
what should i look it? im at my whits end and about to part it out
Old 27 May 2019, 09:28 am
Handy_Cruiser's Avatar
Default Re: keeps overheating
The most common reason for a PT to overheat is failure of the radiator fan. The second most common reason is that the head gasket is blown due to overheating from a failed radiator fan. That's likely the death-nail for more PT Cruisers than anything else.
Here's some links to diagnostics for the radiator fan:
How to test my radiator fan?
Testing cooling fan
Radiator fan bypass test
Radiator/Cooling Fan Check & Connector Fix
Before doing one of these radiator fan tests, make sure you are burping the air out of the cooling system using the bleeder valve on the thermostat housing.
Old 27 May 2019, 09:32 am
fan kicks on with ac on
i see that there are 2 speeds. guess ill have to test this out.
i really hope engine is not toast. all that work for nothing if it is
Old 27 May 2019, 11:06 am
pulled radiator out. a little bit of stuff came out. there was some solid stuff around the filler neck. the fan did kick on with out the ac on. so i have both speeds . the radiator cap seems kinda hard to move up and down.
could that be causing my problems.
if head is bad, what are the symptoms besides overheating
Old 27 May 2019, 11:32 am
Was aftermarket coolant added to the engine before you found the coolant a brown color?
What was the reason for replacing the timing belt?
Old 27 May 2019, 11:34 am
yes. i added aftermarket coolant. i replaced timing belt as i dod not want to have it break as condition was unknown, but it had been replaced before i got it unknown to me. i used quality parts ac delco if i recall
Old 27 May 2019, 12:22 pm
The comment by you that your cooling system is still contaminated is the first suspect with your temperature control problem.
Old 27 May 2019, 01:48 pm
VsandFords's Avatar
Has the thermostat been checked?
Not saying that the cap or contaminates in the system aren't the cause.
It just hasn't been mentioned.
EDIT
My mistake, you mentioned it in the original post about what was replaced.
Old 27 May 2019, 01:57 pm
Pulled radiator out. Reverse flushed it. Some crap came out. Did engine as well . could feel chucks hitting my hand, though water was clear. Did heater core, lots of brown liquid with chunks.I pulled the thermostat out, there was alot of parts of rust on there. I've got a picture. I think I may have solved it. Top and bottom rad hoses were pretty close in temp is hot. Fan does kick on. Its fairly new. I also cleaned up over flow tank. Once car is cooled off, I'll check coolant and go on a road test.
Old 27 May 2019, 02:12 pm
Good Luck with the test drive !
My PT is overheating, help please. Jakestir Tech & Performance Forum 4 19 Jan 2017 09:49 pm
Overheating Gotsea General PT Cruiser Discussions 10 06 Nov 2015 05:49 pm
overheating again help nickels Tech & Performance Forum 9 28 Jun 2014 12:58 pm
PT Overheating Spyder55 General PT Cruiser Discussions 7 10 May 2012 10:57 pm
Still Overheating Cruz2success Tech & Performance Forum 2 19 Jul 2011 10:43 pm
