A/C not runnign very cold
Old 30 May 2019, 03:24 pm
Default A/C not runnign very cold
So ive had this problem for a while and mostly ignored it. When I turn on my A/C I find that it does not run cold, maybe sorta cool at best. On very hot days darn near warm.
The Radiator fan is running, the compressor seems to be turning on (I can hear it), and the car is not over heating. Though maybe slightly warm. The temp gauge stays about at half way after highway travel. The freon/A/C juice is not leaking. it is full to proper level and charged.
I do find that the coolant seems to always be running low, even though I do not see any leaks.
Old 30 May 2019, 03:34 pm
Default Re: A/C not runnign very cold
Keep that coolant topped off. Check your hose clamps and make sure they're tight. And check the over flow hose to make sure there are no holes or cracks in it, either. Have you pressure tested the system? Could be a small leak or the radiator cap is no longer holding the proper pressure.
Old 30 May 2019, 08:04 pm
I have done none of those really. Do you recommend filling the over flow tank, or the radiator directly?
Old 30 May 2019, 10:10 pm
Are you aware there is a high and low speed on the radiator fan?
Old 31 May 2019, 06:46 am
I always fill the radiator directly, right up to just below the overflow hole in the filler neck. The overflow has marks on it, for high and low. I try to split the difference.
Old 31 May 2019, 07:00 pm
Regarding the A/C:
If you're sure the system has a proper charge of freon, feel the very front radiator. That's the system condenser, if operating correctly, it should be warm. The aluminum tubes on the passenger side of the engine compartment carry the freon , they, or at least one of them should be cold in operation. If not the above, I'd suspect a problem with the refrigerant system.
Check the heater / air conditioner controls on the dash. Turning the knobs, you should feel and hear a change in the air flow. If the temperature control knob does not effect a change, it could be a jammed or stuck (hot / cold air) blend door in the system (under the dash).
Upon Cold Start in Cold Weather, Loud Noise?? paulrosenthal Tech & Performance Forum 33 01 Oct 2014 09:55 am
Hot, cold, hot, cold...I'm freezing in here!!!! Ironman Tech & Performance Forum 8 07 Dec 2010 10:51 am
don't run well when cold... yaris Tech & Performance Forum 8 21 Apr 2010 10:22 am
Cold Cold Crazy PianT General PT Cruiser Discussions 13 21 Jan 2004 11:35 pm
cold air vs. hot air ptcruz311 Tech & Performance Forum 3 22 Sep 2003 01:31 pm
