C2100 code from scan tool.
Like Tree7Likes
  • 1 Post By ptcruisersteve
  • 5 Post By Lew360
  • 1 Post By Fk5
Old 12 Jun 2019, 07:06 pm
Default C2100 code from scan tool.
I had a miss fire on cylinder 2 and 3. I swapped some fuses in the fuse box. I also installed a Diablo Trinty 2. I went back to the stock tune but I can't tell which caused the problem and I don't know how to fix it. I'm getting the C2100 code, low battery voltage. Any ideas where to start?
I did fix the miss fire, it was a bad coil. New coil, wires, plugs and valve cover gasket.
Old 13 Jun 2019, 07:13 am
Default Re: C2100 code from scan tool.
You answered your own question, it would appear. As for the low voltage in the battery, take it to your local parts store and ask them to LOAD TEST it. You might have a dead cell. Or you could have simply run it down while chasing the misfire problem.
Old 15 Jun 2019, 02:37 pm
I changed the battery and I'm still getting the code. Anyone have any other ideas? I have searched this and I can't find a solution, the threads always die without anyone figuring it out. I'm kinda lost here.
Old 16 Jun 2019, 12:07 am
Code C2100
Causes:
ECM / PCM
Vehicle battery / Charging System
Auto lock brake module - check the voltage going to the module.
You might have an ABS intermittent condition.
chuzz likes this.
Old 25 Jun 2019, 05:28 pm
So apparently I swapped the abs fuse 34 ABS valve feed into a spot 29 which is empty. Put the fuse back in the correct place and all is well. Pays to double check what you are doing. Thanks for the help and replies.
Old 26 Jun 2019, 09:35 am
Fk5 Fk5 is offline
Glad you found it and thank you for coming back to report. Too often we fail to learn of the solution.
2003 GT 5 speed
162,000 miles
scan tool for CRD UK spec? Alfie1 Europe PT Forum 7 18 Mar 2020 02:53 am
Diagnostic Scan Tool/Code Reader njsteve1 Tech & Performance Forum 19 14 Aug 2016 10:29 am
bought new scan tool, ABS communication trouble jdlmodelt Tech & Performance Forum 6 17 Oct 2014 01:37 pm
OBD Scan tool compatibility AndrewJ Tech & Performance Forum 0 23 Feb 2012 06:17 am
OBD Compact Reader Scan Tool Question sinbad2050 General PT Cruiser Discussions 3 26 Mar 2011 01:10 am
