Losing battle with this car
Like Tree2Likes
Old 19 Jun 2019, 07:11 pm
Default Losing battle with this car
I cant find my original post.. ok guys car still wont start! This is the weird thing now.. we have the original key, the dashlights come on, but it wont crank,no sound,no horn... when you turn the key to the OFF.... the lights are still staying on! Any ideas, before I post it for parts? Im so frustrated since now well be left car less
Old 19 Jun 2019, 07:42 pm
Default Re: Losing battle with this car
OK ive been looking online and thinking maybe its the ignition switch, since hubby had a hard time getting it to go all the way off before..
Old 19 Jun 2019, 07:57 pm
Sounds likely. Sounds like the ignition switch can make it to the run position, but not the start position, and hangs in the run position. Search "replacing ignition switch pt cruiser" on YouTube. There's a number of videos, which says to me it's not an uncommon problem. Although, I've never had the problem myself.
Switch replacement looks pretty straight forward. However, there is a peculiar Torx bit required. It's a "security bit" the bit has a hole in the center because the Torx screw has a pin in the center.
Old 19 Jun 2019, 08:07 pm
LionPT's Avatar
Help!! Lost keys in vent on dash!!
Old 19 Jun 2019, 11:53 pm
Ty. He just told me when he steps on the brake the lights come on..even when it's in the "off" position.
Old 20 Jun 2019, 12:20 am
I would suggest checking to see if the ignition actuator got disconnected from the ignition switch.
Old 20 Jun 2019, 04:48 pm
If you mean the brake lights on the back of the car come on (with the key off), that's normal. Brake lights are wired constantly hot, they always have been. It's a safety thing, the brake lights should work regardless of key position.
Old 20 Jun 2019, 08:29 pm
rob302's Avatar
Those pins snap off really really easy and then you can use a regular torx
Old 21 Jun 2019, 09:06 pm
I meant the dash lights...
Old 21 Jun 2019, 09:07 pm
Ill check into that. Thanks!
OK here goes the battle with the dealer who sold me the car... Dwummer General PT Cruiser Discussions 28 26 Jun 2012 12:07 am
New Battle Cruiser Added VNT General PT Cruiser Discussions 16 26 Mar 2012 07:33 am
months of battle, PLEASE HELP US thegirlwkalideoscopeyes Tech & Performance Forum 13 06 Dec 2011 08:42 pm
Battle at the Beach MB-4 RED N BLACK Southeast PT Forum 0 01 Oct 2003 06:54 pm
