engine
Like Tree9Likes
  • 2 Post By chuzz
  • 2 Post By ptcruisersteve
  • 2 Post By Handy_Cruiser
  • 2 Post By Fk5
  • 1 Post By sanatanadharma
Old 21 Jun 2019, 07:17 am
Default engine
As I was turning into a parking lot it just quit. Turns over, that's it.
Any ideals
Old 21 Jun 2019, 07:43 am
Default Re: engine
First thing I'd suggest you check is the timing belt. They need to be changed every 100,000 miles or so. You don't tell us what year, which engine or how many miles. Need more information. Run the codes on it and post back AFTER you check the timing belt.
Old 21 Jun 2019, 11:48 am
Default Re: engine
I would suggest taking off the camshaft sensor, crank the engine and see if the camshaft is turning.
Handy_Cruiser and chuzz like this.
Old 21 Jun 2019, 12:23 pm
Handy_Cruiser's Avatar
Default Re: engine
Any ideals
If the engine turns over very fast when trying to start, it's likely the timing belt. Another common problem on PT's that causes the engine to just die and not restart is a failed camshaft position sensor on a 2001/2002 model. On the 2003 and newer models, they will normally continue to run roughly in a "limp home" mode when the cam sensor fails.
You will want to check for trouble codes. A failed timing belt will often throw both a cam sensor and crank sensor codes. A failed cam sensor often just throws the cam sensor code. As Steve suggested, you can remove the cam sensor and look at the pilot magnet behind it. This magnet is bolted to the end of the intake camshaft. So it should spin as the engine is being cranked. If it doesn't spin, then that's pretty good proof that the timing belt has failed. But if the engine cranks really fast without starting, that proves it too.
thecabinguy and chuzz like this.
Old 24 Jun 2019, 10:43 am
thecabinguy's Avatar
Default Re: engine
This past year both the timing belt and camshaft sensor bit the dust on my '05 (at different times). At least with the cam sensor biting the dust I was still able to drive the car to the shop, repaired in less than two hours.
Prescott, Arizona, home of forested mountains, 5 lakes (well, four lakes and one big pond), and Arizona's Christmas City (my home 6,000 feet elevation) - 2005 Touring & 2002 Limited - both patriot blue & factory stock
Old 27 Jun 2019, 01:41 am
Default Re: engine
Check also the wires going to the crankshaft sensor.
Old 27 Jun 2019, 09:56 am
rob302's Avatar
Default Re: engine
When mine did that it was the fuel pump. Do you hear the fuel pump cycle/softly whine for a few seconds when are you turning the key from off to run(Not start)?
Old 27 Jun 2019, 11:07 am
VsandFords's Avatar
Default Re: engine
It appears that willieb is out. a one and done.
Maybe he fixed it, or maybe he forgot were his post is.
Old 27 Jun 2019, 11:31 am
Fk5 Fk5 is offline
Default Re: engine
It is more than a soft whine if you have the rear seats out IMHO.
That was his first post with an April 2014 join date. Maybe we will find out what happened to his car in 2024.
2003 GT 5 speed
162,000 miles
Old 27 Jun 2019, 02:00 pm
Default Re: engine
A failed fuse can do this.
NitroPT likes this.
Engine sounds like Diesel on cold start - engine clacking until warm mr_mahoney General PT Cruiser Discussions 30 04 Dec 2017 04:12 pm
removing the accursed engine support bracket & broken bolt on engine mount ushumgal General PT Cruiser Discussions 6 11 Dec 2015 04:47 am
2004 Engine misfire and flashing check engine light fg1911a1 General Turbo Discussions 15 26 Jul 2014 06:20 pm
Converting 2002 engine to a 2003 engine - ECU RomanSouthAfrica Tech & Performance Forum 2 08 Apr 2013 04:33 pm
Can 2001 Engine be replaced with Newer Engine harleysforfun General PT Cruiser Discussions 1 07 Aug 2009 01:38 pm
