Old Head Gasket Looks So-So?
  • 1 Post By pt06
Old 28 Jun 2019, 02:49 pm
Default Old Head Gasket Looks So-So?
We were getting air into the system and overheating, so I finally decided to do the head gasket.
I just got it off, and looking at it, it doesn't look obviously busted, although it is pretty gnarly in general. Could it still be the source of the problem?
I suppose I only have one option any way: install new HG and hope for best.
But I am hoping that is going to be the fix.
2001 non-turbo 2.4L
thx
Old 28 Jun 2019, 02:50 pm
rcktpwrd's Avatar
Question Re: Old Head Gasket Looks So-So?
have any pics of the gasket, head and block?
Joel
www.rcktpwrd.com
Old 28 Jun 2019, 03:21 pm
Default Re: Old Head Gasket Looks So-So?
You don't re-use a none metal head gasket. Replace the used head gaskit gasket.
Based on what you have posted IMO it is not the head gasket.
Old 29 Jun 2019, 09:11 am
My last two head gasket failures (honda & olds) were caused by aluminum head corrosion bypassing the gasket. Just replacing the gasket wouldn't be enough.
Old 29 Jun 2019, 01:45 pm
What do you do about aluminum corrosion?
Old 30 Jun 2019, 10:02 am
Usually the head is replaced but I'm cheap and own a heliarc welder so I welded and machined (wood router) the pits flush.
Did you ever do a leak down test?
Old 01 Jul 2019, 12:36 am
I replaced a head gasket on a 2.5 Mopar. The cast iron block surface had little corrosion and cleaned up nicely. The aluminum head was pitted. I brought it to a machine shop, the owner said it looked normal for a 125,000 mile engine. He machined it flat, giving it a smooth finish. Lasted another 10 years. A good machinist has experienced more than the average Joe.
circus likes this.
Old 01 Jul 2019, 12:21 pm
OK, thanks for info.
After researching, I can say neither the head nor block surfaces are corroded/pitted.
I cleaned the heck out of them and installed gasket. Hoping for best.
(No machine shop around here... Napa wanted ~$500 for a reman head.)
Head gasket going on friends PT. Is a gasket seal additive a decent last ditch fix? ptprice General PT Cruiser Discussions 24 10 Oct 2018 06:07 am
PT Getting New Cylinder Head, Head Gasket, Water Pump. What Could I Mod? 06turbolite Tech & Performance Forum 8 14 May 2013 09:16 am
03 pt turbo oil in water new head gasket fresh head strokedoutss General Turbo Discussions 7 17 Apr 2013 04:22 pm
Whats the Head flat spec. for head gasket. Busted_PT Tech & Performance Forum 7 26 Apr 2012 08:16 am
WARPED HEAD / SCORED CAMSHAFT / BLOWN HEAD GASKET amadeo Tech & Performance Forum 5 12 Apr 2011 01:03 am
