Klunk
Like Tree9Likes
Old 03 Jul 2019, 10:53 pm
Default Klunk
I have replaced the engine mounts, but still hear a 'klunk' when we turn hard or hit a bump. Would that be a shock/strut?
Old 04 Jul 2019, 07:30 am
Default Re: Klunk
Could be the top strut mount. How many miles are on your PT?
Old 04 Jul 2019, 10:18 pm
SpaceMouse's Avatar
Default Re: Klunk
The lower control arms are notorious for getting noisy with high mileage (both the bushings and the ball joints wear out and get rattly). The sway bar bushings also tend to disintegrate after a while.
My local shop quoted me $1500 to replace these parts, along with the shocks, with just basic pieces. I did the job myself one weekend, with premium pieces from KYB and Moog, for $400 or so. Ride is firmer and better controlled, no more rattling.
What did you do to your PT today?
chuzz likes this.
Old 05 Jul 2019, 08:18 am
Default Re: Klunk
about 140K
Can any of these cause shake at 65mph?
My son says the steering wheel shakes really bad at 65
Old 05 Jul 2019, 10:45 am
LionPT's Avatar
Default Re: Klunk
Originally Posted by 3DPiper View Post
about 140K
Check car for bad tire (broken belt) or bent rim.
VsandFords and chuzz like this.
Old 05 Jul 2019, 12:32 pm
Default Re: Klunk
It could also be a bad half shaft (axle). I had a Caravan that would shake the hell out of you at 45 mph. Above or below, it was okay. Replaced the passenger side half shaft and all was well.
Old 05 Jul 2019, 01:40 pm
rockandroller's Avatar
Smile Re: Klunk
My klunk was lower control arms, good price at RockAuto and the local shop didn't charge an arm and a leg for replacement
2004 'Turbo Lite'
Old 05 Jul 2019, 03:03 pm
Default Re: Klunk
I think I'll try to replace the lower control arms first and see if that solves the problem..
Thanks everyone!
Old 05 Jul 2019, 03:26 pm
VsandFords's Avatar
Default Re: Klunk
It might be worth your time to have a shop look at it. Some shops will do an inspection, let you know what's wrong and tell you what it will cost for them to fix with NO charge. They want you to come back for the repair. Some will do an inspection for a small fee. Probably less money than a control arm. The last time I took our Nissan van in for an alignment, they put it on the rack, found out the inner tie rods where worn. I took the van home to replace them myself with NO charge. I did go back and let them do the alignment. Good for both of us.
I recommend you check or have a shop check your suspension before throwing parts at it. You might spend a LOT of time and money before finding out that it is a $20 piece.
As always, my opinion from this side of the internet.
Fk5 and chuzz like this.
Old 05 Jul 2019, 05:20 pm
SpaceMouse's Avatar
Default Re: Klunk
THIS.
I did the same thing, knowing that there are things that typically wear out, but not being certain that I knew exactly where to look. Our local Brake Masters offers a free "safety inspection", so I figured why not let them have a look. They confirmed what I suspected, and I saved a bundle by doing the work myself (to say nothing of using better parts). I'll have them do the front end alignment (don't have that sort of equipment in my garage), but nothing wrong with taking advantage of their services.
VsandFords likes this.
Klunk from rear wb2kki General PT Cruiser Discussions 8 08 Apr 2014 11:09 pm
