Gas pump nozzle shutting off history
Old 11 Jul 2019, 07:27 pm
Default Gas pump nozzle shutting off history
Hi again,
I fixed my two main problems, and seem to have either installed a new one or the defect covered this issue....
Initial problem was the car posting p0440, p0441 and an occasional gas cap loose error.
I also had an issue with the gas gauge never reading full, even after making sure the tank was full.
I pulled the gas tank, replaced the NVLD switch/pump and the fuel level sending unit, cleaned the evap filter and reinstalled the tank. BOTH problems were resolved but now I can't fill the tank without the nozzle constantly shutting off!
My questions are...
First, can the NVLD asm cause this problem? It was harder to blow through than the original.
Second, I understand there is a check valve in the filler hose in the tank. Can someone explain how it works? I can't find that information online or in the service manual...
I am sure that I didn't pinch any of the many hoses on the top of the tank..
Thanks, Kerry
History Channel: History of the Car PGBCruiser PT Cruiser News and Rumors 9 17 Aug 2017 05:27 pm
bubbling and Gurgling noise when shutting off Seedman14 General PT Cruiser Discussions 2 20 Jun 2012 12:36 pm
Low Idle Almost shutting down Sam2627 General PT Cruiser Discussions 2 03 Apr 2012 08:40 pm
please help, car shutting off misslee007 Tech & Performance Forum 4 17 Jun 2011 04:49 pm
ac not shutting off rjsmurf Tech & Performance Forum 1 26 Oct 2008 05:21 pm
