Engine vibration at idle.
Like Tree4Likes
  • 2 Post By ptcruisersteve
  • 2 Post By ptprice
Old 22 Jul 2019, 08:14 pm
Default Engine vibration at idle.
Originally I post this question on "Tech & Performance" Forum
but got no response.
Hoping to get input here.
Engine vibration at idle started after P0401
code came on second time. First time code came and
disappear,then second time it came back after about 3 months.
Decided to change EGR valve with modulator.
Since I was already under the hood, replaced
spark plugs gapped at 0.42 "champions 443 copper",ignition coil,new wires,
throttle body cleaned new gasket installed,
pcv valve and hose, egr valve and modulator 2 new gaskets and rubber ring. all parts confirm oem.
After all installed, started engine and noticed that before
engine started immediately, now it takes two turns for engine
to start. Is it normal for engine to start on second
turn,rather then immediately?
Rpm steady.
No codes.
After 2 week and 100 miles, engine ignition will take sometimes
several turns to fire, sometimes 1,5 turns to fire.
Vibration still there almost at the same level.
What could be other causes of engine vibration?
I read forum posts on vibration causes,
engine mounts and timing belts seems to be
prevalent causes.
In my case timing belt was replaced, this was verified
by service shop.
Bought car used.
2002 PT LIMITED 93000 miles
Thank You.
Old 22 Jul 2019, 11:44 pm
Default Re: Engine vibration at idle.
I would suggest hooking up a vacuum gage and see what the results is. Report what you find.
chuzz and kurabess like this.
Old 24 Jul 2019, 11:18 pm
Thank You for reply.
Will report on Your suggestions.
Jack.
Old 25 Jul 2019, 09:16 am
ptprice's Avatar
SOOO BIG had a timing belt failure at around 80,000 miles.
Unfortunately it happened on the interstate just as I'd slowed from 80mph to pull off for gas. I was waiting at a light on the exit to a small south Georgia town when the timing belt failed at idle. Nothing but the belt was damaged. I was near a Wilco parking lot I managed to roll into, found the store manager hooked me up with truck mechanic who did the job right there on the asphalt. Later, I discover he'd not correctly installed the belt idler.
Over time the engine began vibrating. Just slightly at first. I cruised along for nearly 8,000 miles as it became a progressively intensifying engine vibration, developing finally into the belt idler bearing failing. That shrapnel trashed the belt, pump, all the innards and the cover. The whole shebang! As it was a massive tear down, I did a complete re'do including new external belts, a new radiator while it was out and four new mounts.
I'd figured because the timing belt had been replaced, I was secure in assuming the vibration couldn't possible be a timing belt problem. But the second time it failed big time! Of course the second repair was the charm. Done by a trusted local mechanic. SOOO BIG's good for another 100,000 miles now.
At least consider closely checking the work done on installing the timing belt and it's constituents as it apparently was done before you owned the PT.
Good Luck. Happy PTin', ptprice
rockandroller and chuzz like this.
SOOO BIG 2005 PT CRUISER, LIMITED EDITION, SIGNATURE SERIES
Cool Vanilla White, 3 Coats. 2.4 DOHC 16V SMPI Eng. Vanity Cover, 4 Spd. Auto Trans. 2.6 Overall Top Gear, Lock-up Torque Converter. PT Chrome Clad 16" X 6" Wheels, P205/55 R16 Cooper Starfire/Solarus tires, Touring Suspension. Chrome Package; Side Spears, Grills, Fuel Filler Door, Door Locks, Handles, PRND3-1 Bezel, Silver/Chrome Shift Ball/Knob, Bright Spoke Leather Tilt Steering Wheel. Chrome Tail Lights, 3/8" Belt Trim. Cruise Control, Power Mirrors, A/C, Deep Tinted Sun Screen Glass, Power Moon Roof, Fog and Back-Up Lights, Rear Spoiler, Variable Front Wipers W/Washers, Rear Wiper/Washer, Key less Entry, Replacement 2001 Dark Taupe Grey Suede/Leather Trim Seats, Dual Under Seat Storage Drawers, Drivers Side Power Seat Height Adjust. Full Length Console, Locking Glove Box, Overhead Temperature/Compass Console, Rear Shelf Panel, AM/FM CD GPS Navigation Radio, 6 Premium Speakers, Back up Camera/ 7" Monitor.
Old 01 Aug 2019, 12:24 am
First time using scan tool
Bit of learning how/to.
As far as vibration, scan show
that MAP sensor way off.
Think MAP sensor maybe problem.
MAP sensor parameters according to
online info.,not working correctly.
Will double check once
We Obd2 book arrives.
Hopefully will be able to
resolve my engine vibration
and fuel consumption.
Thank You.
Jack.
Old 01 Aug 2019, 12:45 am
Problem goes both ways.
In my case service shop checked timing belt.
Was told "all good there", how they come to that conclusion
do not know, but was told above was done.
That was two years ago.
Jack.
Old 04 Aug 2019, 01:06 am
The map sensor is one of the controls for the EGR valve.
Check the wiring harness over the driveshaft. Early PT harnesses sometime sag and wear thru the plastic insulation and cause intermittent problems.
Old 07 Aug 2019, 10:15 pm
Red face Re: Engine vibration at idle.
Thank You for reply
Jack.
Engine vibration at idle. kurabess Tech & Performance Forum 0 04 Jul 2019 07:43 pm
Vibration at Idle somerandomperson Tech & Performance Forum 10 15 Apr 2017 08:32 pm
Idle vibration garner49 General Turbo Discussions 14 07 Apr 2013 09:48 pm
Idle vibration, Let me see of I have this right Gru General PT Cruiser Discussions 6 25 Mar 2013 03:56 am
Idle vibration... garner49 General Turbo Discussions 6 17 Nov 2009 06:40 pm
