No heat
  • 1 Post By lizardtrack
Old 26 Jul 2019, 06:25 am
Default No heat
I can't get any cabin heat. I flushed the heater core, thermostat and radiator. It blows cold air but not hot. Any ideas?
Old 26 Jul 2019, 07:57 am
Default Re: No heat
Does it in fact have a thermostat in it? If so, maybe it's not a 195 but a 180 or 160. Original equipment is a 195. If that's okay, I'd suggest you check the temperature control cable. It's adjustable and maybe one of the clips has come loose? IDK, just guessing. Did you try back flushing the heater core too?
Old 26 Jul 2019, 08:33 am
Fk5 Fk5 is offline
Default Re: No heat
+1 on the temp control
Assuming the car is getting up to temp. These things can stick. It is fairly common. Mine is getting there. Knock on wood I haven't had the problem yet. On my old Ramcharger, the cable broke and we would just move the valve under the hood. Ah, a much happier, simpler time.
2003 GT 5 speed
162,000 miles
Old 27 Jul 2019, 07:40 am
Default Re: No heat
I'm just wondering where you are that you need the heat right now. My eggs are frying inside my shorts this time of year here in Hell.
Old 27 Jul 2019, 04:41 pm
Default Re: No heat
I don't want to wait till it's raining to patch the roof. thanks for the input.
chuzz likes this.
Old 28 Jul 2019, 06:56 am
Default Re: No heat
Let us know if you figure it out.
Old 04 Aug 2019, 01:12 am
Default Re: No heat
Check the coolant level. It should be filled up to the top under the radiator cap. Check when the engine is cold.
No heat at all.....06 PT aluisi Tech & Performance Forum 4 18 Feb 2013 01:37 am
Over Heat ? tbcrusier Tech & Performance Forum 34 29 Jun 2011 07:08 pm
Heat is Not Getting Hot - Help! jrennard3 Tech & Performance Forum 21 14 Dec 2010 12:05 pm
Over heat, need some help hulk2 Tech & Performance Forum 29 31 Dec 2009 06:29 pm
no heat mrbill General PT Cruiser Discussions 10 20 Jan 2009 12:14 pm
