Cranks but no start
Like Tree4Likes
Old 30 Aug 2019, 05:30 pm
Question Cranks but no start
Good afternoon,
I have had a good run with my 2006 PT Touring. I have recently had my mom driving it for the past 8 months and she took it out over a week ago and it died on her leaving a parking lot. She said it seemed like it ran out of gas.
I went to where she left it (was able to coast it back into a parking space) and hooked my ODB2 scanner up to it and there are no codes. It turns over but will not start. I had it towed to the house.
I have been on and off troubleshooting it for over a week now.
I pulled the fuel line to the fuel rail at the firewall and had my wife try to start and no fuel.
All fuses are good.
Battery is Fully charged and I am keeping it on my trickle charger between troubleshooting days.
I have checked fuses 18,26,23,32 for voltage during cranking and I am good.
I do not hear the pump come on at key on ignition on.
I see the RPM gauge come up at crank.
I double checked for DTCís after cranking and still no luck.
I suspect the fuel pump relay in the PMC but would like a test point to verify and I canít seem to find one.
How would you suggest proving my theory at this point?
Thank you
Scott
Old 30 Aug 2019, 08:06 pm
Default Re: Cranks but no start
Many things can seem like a car ran out of fuel. I'd looking elsewhere first.
You might consider some common PT failure points:
1) Camshaft position sensor
2) Coil pack
Codes don't always help, as you have already learned.
Bob in Liberty MO
Old 30 Aug 2019, 08:22 pm
Being that your from the rust belt OHIO, I'd be checking the ground at the fuel pump. No need to remove the tank, if you search you will find you can cut a 3 sided flap in the floor above the tank and check for ground which I had found in my 06. There are two one for the fuel pump and one for the gauge. I ran jumper to the body and all was good.
I used an air chisel to make the flap to avoid cutting wires.
73 Charger SE
Several Neons some flips
01 Sebring flip
20 Miles South Of Pittsburgh
Old 30 Aug 2019, 08:47 pm
I'd use a test light to see if the fuel pump is getting juice, at least initially after turning the key.
Old 30 Aug 2019, 10:09 pm
_PTGT03's Avatar
install a fuel pressure gauge on the fuel rail test port
Old 31 Aug 2019, 08:09 am
Thanks everyone
I was hoping to avoid cutting a hole in the floor or dropping the tank to test but I will reconsider.
I will search again for the location to cut the flap. I saw that when I was searching earlier this week.
I will check cam position sensor, the coil packs are good.
I get no flow from the fuel line with key on.
Thanks again.
Ill let you know what happens
Old 31 Aug 2019, 07:45 pm
I pulled the TIPM and flipped it over. When I turn the key on I have voltage at the Blue/orange wire on pin 11 on connector 7.
I am guessing it is a bad ground connection or an open in the pump motor since I can not read any resistance from this wire to ground.
I am going to cut the floor open since it is in my crummy gravel drive and I can not get it in my garage due to storage needs from a family member. The path of least resistance is the floor.
I will post updates on what I find.
Old 01 Sep 2019, 10:56 am
Maybe someone could tell you where the grounds are attached to the body for the Fuel Pump
I also had a PCM go bad which caused the same thing- no start 2006
ohioscott likes this.
73 Charger SE
01 Sebring flip
Old 01 Sep 2019, 11:09 am
Thanks JoeX
I found I only have 10.8 volts at Pin 4 on the wiring harness connector at the top of the fuel pump. I also have 500 ohms to ground on PIN 1 with the key on. I donít know if this is a good test or not since I am using the body sheet metal to test my pin 1 to ground. I am going to run a jumper back to the battery ground on the fender by the PCM to see what it looks like. I found the harness connector at the passenger door underbody but need to verify what pin I need to check there.
The troubling part is I only have 1 ohm between PIN 1 & 4 on the pump itself. I would have expected more.
So it is more research to figure this out.
Old 01 Sep 2019, 10:50 pm
_PTGT03's Avatar
this is a very simple problem since you determined there's no fuel pressure or flow at a key-on.
jumper power to fuel pump relay socket.
open the connection at the fuel pump and check for B+, 12.4
check voltage on the ground, to chassis for anything not 0.1 V is a problem.
if you have voltage at the end of the fuel pump connector at the right amount, replace the fuel pump relay.
check the resistance of the fuel pump motor winding from the fuel pump side connector. between 1 to 4 ohms is acceptable. anything over this value, or infinite 'open' ohms go ahead and replace it.
the other two terminals on the plug are the fuel level sender should be from 120 ohms at empty to something like 400-500 ohms at full
Tags
electrical, fuel pump, gen 2, no start
01 pt cranks, no start. jeanm Tech & Performance Forum 8 28 Oct 2017 03:31 pm
06 PT cranks no start drumrooster Tech & Performance Forum 36 25 Feb 2017 09:22 am
Cranks, won't start (bad PCM ???) dxv77 General PT Cruiser Discussions 14 26 Jul 2015 05:19 pm
05 PT cranks but won't start. Noah1 Tech & Performance Forum 5 22 Jan 2015 03:38 am
Cranks but want start stickkman99 General PT Cruiser Discussions 8 04 Aug 2013 12:00 am
