It's normal that whenever you want to do something, you have to do something else first.. I need to replace the shifter bushings, under the console, in my 2001 5 Speed Cruiser (rear disk). Okay, easy enough. I have the Boogers, but I can't remove the console because the parking brake handle is too low to get the console off. Somehow I have to relax the adjustment to lift the handle more... Got any ideas. ...Thanx in advance.
Not necessarily pertaining to the PT but I recently did a brake job on a 05 silverado, and to reattach the parking brake cable I had to remove the drums to allow the arm on the brake more movement.
There were no adjustment brackets to loosen
Addicted to Mopar You can tell how old I am.. 65 Dodge Coronet 6 cyl 2dr Post 66 Ply Satellite with 273 engine swap to 69 340 4spd 70 340 4spd Dart Swinger "Those were the days my friend" 73 Charger SE Had a few Vetts on the way 69, 85 Several Neons some flips 01 Sebring flip Cruiser's 01, 220K Gone to a new home Cruiser 03 133K Gone to a new home Cruiser 06 110K Project Gone to new Home Cruiser 05 Ltd 120,809 bought with broken belt Oct2015 May 16 Resurrected to once again roam the streets. 20 Miles South Of Pittsburgh |
How far back do you need to get it? I didn't even take my console all the way off. I just pulled it up. If you really need to get it off, you should be able to undo the front screws first, and it should smoosh forward enough to get it off. It is plastic and pretty bendy.
2003 GT 5 speed 162,000 miles |
![]() Quote:
Then there's the fun of releasing it afterward...
As said previously it does need to be upright to remove the console. You are removing the effect of the clockspring on the tension by inserting a drill bit or something into the base of the lever first aren't you?
Would removing the arm rests from the front seats help? I've never had to remove one, so am just asking.
![]() Aspire to inspire before you expire. |
Following CHuzz... Could you tilt the seat back far enough to help
it would be a heck of a lot easier to just un adjust the e brake shoes... for the op's info, that would be a flat tip screwdriver tilted DOWN with the blade on top of the adjuster, then lever the screwdriver towards the car. to re adjust, the screwdriver goes towards the ground. I like it adjusted to around 3 clicks if you live in the mountains- but make sure it works before you hand it over to your significant other or- ahem, teenager...
Thread Tools | |
Display Modes | |
Parking Brake Cable | famikert | General PT Cruiser Discussions | 2 | 10 Dec 2015 01:14 pm |
Parking Brake/Brake Dash Light | PhxPT | Tech & Performance Forum | 4 | 24 Jan 2013 08:41 am |
parking brake | stevas | Tech & Performance Forum | 1 | 04 Jan 2011 11:47 am |
Drum brake replacement Parking brake cable | Dorkygrin | General PT Cruiser Discussions | 2 | 28 Mar 2009 07:53 pm |
parking brake light going on??? | yobiebs | Tech & Performance Forum | 8 | 01 Nov 2007 09:25 am |
