Unfortunately, my PT is still overheating
Old 13 Sep 2019, 05:47 pm
Default Unfortunately, my PT is still overheating
So my 2004 PT Cruiser LTd Ed Turbo is still overheating.
I replaced the fill spout, thermostat, gasket and cap. Then I had Jiffy Lube flush it out and refill it.
I was able to drive a bit, but it eventually hit the halfway mark, then started going over. The high fan came on, but it struggled to keep it cool.
I don't know if it continued to clime, since I pulled into Starbucks and I'm letting it cool down now.
The guys at JL said they didn't notice any leaks, or any problems when flushing it out.
So I'm assuming it's the water pump. Which means the timing belt needs to come off and that will be expensive.
I can't think of anything else it could be.
Old 13 Sep 2019, 06:13 pm
Default Re: Unfortunately, my PT is still overheating
Did it overheat at high or low speeds?
Old 13 Sep 2019, 06:16 pm
Originally Posted by ptcruisersteve View Post
Did it overheat at high of low speeds?
I was driving around downtown Redmond, so I don't think I ever went over 30 MPH.
Old 13 Sep 2019, 06:21 pm
Any codes triggered? It is common for the low speed fan to quit working. Check the fan first.
Old 13 Sep 2019, 06:28 pm
No, no codes. The check engine light doesn't come on, except normally when I start the car.
I think the low fan is working, I thought I heard it. I definitely heard the high fan come on.
Shouldn't the high fan be able to cool it down as well?
Old 13 Sep 2019, 08:11 pm
Does the fan come on when you first start the engine and then turn on the A/C?
If the low speed fan is good you need to have your engine coolant system pressure tested to make sure it is not leaking.
Old 14 Sep 2019, 09:41 am
There's a water pump inlet tube connected to a radiator hose that rusts. Check that first.
Double check that the O-ring included is the right size. Mine wasn't.
Old 14 Sep 2019, 01:10 pm
I haven't checked that, but I will and let you know. When I start the car I don't hear a fan come on, it usually comes on when I drive and the temperature gets close to teh halfway mark, then I hear the low fan.
Once the car heats up to just below the halfway mark, the low fan pretty much is always on.
I do hear the high fan come on, so I know that ones works.
Old 14 Sep 2019, 01:12 pm
I didn't know about that one. I'll check it later today.
When I replaced the fill spout I found some rust colored muck inside, and also in the upper hose.
But when I had the guys at Jiffy Lube flush it out and refill it, they didn't mention if it was clean or dirty.
I'll assume it's rust and was dirty.
Old 14 Sep 2019, 02:27 pm
Doesn't matter what's inside, the inlet tube rusts through then leaks near the O-ring. I wonder how many water pumps were painfully replaced because of that easily replaced tube?
Overheating. again. JTOco Tech & Performance Forum 1 07 Jul 2014 06:49 pm
overheating, is the fan come on without the a/c on ? beel61 Tech & Performance Forum 2 28 Jun 2014 12:47 pm
Overheating AGAIN! 03PTCruzzin Tech & Performance Forum 4 19 Jun 2014 01:17 pm
Overheating kporcenaluk Tech & Performance Forum 5 01 Sep 2010 08:48 pm
01 PT overheating Av8ion Tech & Performance Forum 11 30 Dec 2009 12:16 am
