BETTER ADHESION PRODUCTS FOR VARIOUS PLASTICS
Like Tree5Likes
  • 1 Post By _PTGT03
  • 2 Post By RickinPA
  • 1 Post By NitroPT
  • 1 Post By soonercruiser
Old 28 Sep 2019, 05:29 pm
soonercruiser's Avatar
Default BETTER ADHESION PRODUCTS FOR VARIOUS PLASTICS
What may I be missing here?
Just the name "JBWeld" used to conjure up thoughts of a an especially strong adhesive bond.
But, when I look at a store with a really good selection of adhesives, JBWeld is just a "brand" name, with all kinds of adhesives that are already on the market - like two-part epoxy, and gasket Silicone.
When I finish my Morette headlight project, I am going to need a really strong and dependable bond between the Morette Urethane and the OEM plastic plastic mounting screws.
Do I need to consider a plastic welder first; reinforced by epoxy?
Frank, aka SOONERCRUISER,
Old 28 Sep 2019, 06:20 pm
LionPT's Avatar
Default Re: BETTER ADHESION PRODUCTS FOR VARIOUS PLASTICS
Plastic Welder
Old 28 Sep 2019, 07:33 pm
_PTGT03's Avatar
You best decision making process will be to determine the types of plastics to be joined, and then call or email the technicians' from 3M, Lord-Fuser, and other popular industrial adhesive manufacturers.
soonercruiser likes this.
Old 28 Sep 2019, 08:26 pm
I would determine what plastics are involved. Plastic fasteners are often Nylon. Molded plastic parts are often (but not always) ABS. Parts in the polyolefin family (Nylon, polyethylene, polypropylene, etc.) are notoriously hard to bond. And of course you mention urethane, i.e. polyurethane. It has it's own issues due to flexibility. Plastic parts are often marked with a recycling triangle that has a letter code indicating the plastic type.
Google it, for example "adhesive for polyurethane". There's a lot out there.
Sourcing the adhesive; maybe a hardware store will carry what you're looking for, but more likely an industrial supply will be needed. I'd recommend McMaster-Carr www.mcmaster.com I deal with them regularly at work. Their site includes informative pages, e.g. "About Structural Adhesives".
Just be aware that as you get into industrial 2-part adhesives they come in a dual barrel cartridge that requires a separate plunger, gun and nozzle for dispensing. That could get a little pricey. It may be possible to rig something up to pump out the adhesive and mix it in a small container by hand, but I never tried that.
Old 28 Sep 2019, 10:17 pm
I go through this all the time and have given up on calling and talking to the so called technicians at these chemical supply companies.
The best advise is try an area with the parts you will be using.
I recently repair a poly plastic stock air box housing (see thread: http://www.ptcruiserlinks.com/forum/...tml#post707736 ) and was told JB would not bond to it. Hmmm Not only did it bond to it, I dried it for a fasner and painted the projects. It now looks like factory...well more or less.
I also was told years ago that the use of it to fill a void in a super charger would not be wise. Hmmm again bought the "JB weld in commercial quarts quantity and fill a supercharger housing area to increase the noise the Super Charge makes. This mod has now been copied and is frequently used for a couple decades with out any failure.
To be clear so I do not get misunderstood I have also used JB weld on some project and it will not stick at all. My soccer ball got a hole in it and the JB weld failed to seal it...
I also realized a new use for JB weld and that is a economical way to make molds of some parts and then use other material like fiber glass to actually make the new part.
Old 29 Sep 2019, 12:39 pm
Thanks to everyone for the recommendations.
I do believe in testing adhesives before actually "doing" it!
Nitro!
Again, you just throw out the term "JBWeld", but you don't specify what JBWeld product!!! Two-Part EPOXY????
AND....
It just dawned on me that as a licensed provider, I can actually order some dental lab polymethylmethacryclate.
We use it to add the powder to the liquid to make dental impression trays, and control the amount and setting time.
I have used it for all kinds of repairs around the house, and it is hard plastic.
_PTGT03 likes this.
Old 29 Sep 2019, 01:05 pm
Nitro!
Like you "we" you and I have been using JBWeld all the way back in the 70's sold by JC Whitney... so when I say JBWeld it is the 2 part original epoxy.
Sorry for the confusion.... I still forget that these days no one company seems to be original anymore.....
Interior plastics are painted? KroozinNb00zin Interior Accessories Forum 5 30 Jul 2015 09:04 pm
GT CRUISER BLACK PLASTICS...--CARPET. StealthMode Classifieds: For Sale/Trade 0 17 Apr 2012 11:20 am
looking for interior door plastics HawaiianPt Interior Accessories Forum 2 25 Sep 2010 03:47 pm
Two new products turbomangt Vendors & Buyers Forum 3 25 Jul 2003 09:19 am
painting plastics OurPTGT General PT Cruiser Discussions 8 09 Apr 2003 01:00 am
