LOST MY INSTRUMENT CLUSTER LIGHTS!
Like Tree3Likes
Old 25 Oct 2019, 02:48 pm
soonercruiser's Avatar
Default LOST MY INSTRUMENT CLUSTER LIGHTS!
So, I was swapping out all my interior lights for LEDs, after draining the new battery from leaving the hatch ajar Tuesday for about 6 hours.
I was working on the very last bulb, the cup holder illumination....regular incandescent bulb was working....and tried in the LED ....musta been reversed polarity....NO!
Now the regular incandescent bulb won't even work! No juice!
****And, my instrument cluster is no lighting or working!
(along with the HVAC lighting not illuminating)
Since it's just not only the cluster, but also the cup light, I'm thinking fuse.
I had done a pretty good job of saving all the diagrams and charts on my computer.
Checked all the applicable fuses under the dash...Nothing!
Checked all the fuses in the PDC.....Nothing!
Any thoughts????
Frank, aka SOONERCRUISER,
Old 25 Oct 2019, 04:53 pm
rockandroller's Avatar
Default Re: LOST MY INSTRUMENT CLUSTER LIGHTS!
hmmm... pulled a major ground wire loose, when opening something up? ( I do not have wiring diagrams handy)
soonercruiser likes this.
2004 'Turbo Lite'
Old 25 Oct 2019, 07:39 pm
Since everything worked until I pulled the cup holder bulb.....
it would lead one to believe there is one there????
Could be I have a bad fuse that looks good a first sight.
I've read pretty much all the old "Instrument Cluster" threads, and the ones that come up on Google....with no solution so far.
I guess I can pull the center bezel, radio, and look in there for a loose wire.
Otherwise that leads to the question...WHAT GROUND WIRE being loose would cause me to loose the instrument cluster lights, HVAC lights, and the cup holder light???
Old 26 Oct 2019, 07:27 am
I don't know if it's connected or not, Frank, but take a look at the ground on the back of the cigarette lighter or outlet on the dash or console. I don't even remember if there is one!
Old 26 Oct 2019, 11:15 am
Thanks for the idea Chuzz!
I am planning on taking out the radio and bezel and looking in there today.
But, that cig lighter/outlet is still working.
I tested it early on.
Old 26 Oct 2019, 11:18 am
Here it is...
Old 26 Oct 2019, 01:53 pm
rcktpwrd's Avatar
Cool Re: LOST MY INSTRUMENT CLUSTER LIGHTS!
Visual inspection of a fuse doesn't always show a bad one. You have to check for continuity with a meter.
LionPT likes this.
Joel
www.rcktpwrd.com
Old 26 Oct 2019, 03:37 pm
You are correct!
So, I learned to do one more thing with my multimeter; and all the concerned fuses test OK.
I just got done tearing down the center dash bezel, radio, and HVAC controls.
Everything seems OK. No special ground wires there.
Everything comes from the harnesses.
Disconnected the battery for 10 minutes, just in case.
No effect.
Old 28 Oct 2019, 03:16 pm
Red face Re: LOST MY INSTRUMENT CLUSTER LIGHTS!
So, yesterday I came out and the battery is dead again for the second time in a week.
So, I've got a short/draw down on the battery somewhere.
After jumping to start I noticed that the parking lights don't work whether one themselves, or with the headlights.
But, Signals and flashers do work fine.
At that point I was convinced that it was a short in the Multifunction switch.
Found one reasonably at Autozone.
But, That isn't the problem either.
So, I guess I will unhook the battery until I head to my fav dealer on Wednesday.
Old 30 Oct 2019, 02:13 pm
Got my dead battery (draw) and cluster lights worked out today at my fav dealer.
Rear door popper controller was drawing too much juice; even when popper solenoids are not being activated!
Instrument cluster was fuse #5!
NOT ONE I had ever seen listed as a possible source!
(Thought I checked the all; including continuity.)
Now, I have to figure out how to route the power to the door popper controller...as it now comes off the line to the interior lights, electronic door locks, and rear cargo light!
I'm thinking that I will just tap into that separate fused line to the battery for the popper solenoids; and route that thru another switch near the dash....so it is never on when I don't need it!
Somewhat inconvenient.
I will also call the company to see why the controller is drawing that much power.
No Instrument Cluster or overhead lights wingman55 General PT Cruiser Discussions 2 30 Jul 2017 11:01 am
Instrument cluster lights won't extinguish. NLAlston General PT Cruiser Discussions 5 15 Feb 2017 10:21 am
instrument cluster lights dim slash General PT Cruiser Discussions 0 25 Jul 2012 03:14 am
instrument panel cluster lights??? msmarvel Interior Accessories Forum 7 19 Sep 2011 06:09 pm
Instrument Cluster Lights kappa_kruiser Tech & Performance Forum 1 22 May 2008 01:03 am
