Both P0480 and P0481 Lit Up
Like Tree4Likes
  • 2 Post By sanatanadharma
  • 1 Post By sanatanadharma
  • 1 Post By RCSnyder
Old 26 Oct 2019, 06:38 pm
Default Both P0480 and P0481 Lit Up
Popped both codes at the same time this week on my '03 Touring. The fan isn't turning in any mode of operation. Hmmm.
My first time actually getting codes when the fan stopped working, so I do expect something different that I've seen in the past.
Anyway...
Checked the fan for low/high speed continuity and checks good. Plugged in a good spare fan and tested all modes with no luck.
Swapped in what should be good high and low speed relays and no luck. I am confident the high speed relay used is good, but cannot verify low speed replacement.
Is there a single point of failure I should be chasing. And/or would a bad low speed relay pop both codes.
And...
Maybe related, maybe not, the shift lock cable under the dash came adrift and was snagging the steering yolk on right turns when the codes popped. Cable re-secured, but it was bumping up against the steering column wire loom when it was snagging.
Thanks in advance.
Bob in Liberty
Old 29 Oct 2019, 10:13 am
Default Re: Both P0480 and P0481 Lit Up
Originally Posted by RCSnyder View Post
Is there a single point of failure I should be chasing. And/or would a bad low speed relay pop both codes....
Thanks in advance.
Bob in Liberty
Fuse #5 (40 amp) in the under-hood PDC (ower distribution center)
Handy_Cruiser and chuzz like this.
Old 30 Oct 2019, 07:52 pm
I gave that fuse a visual once-over, but will recheck tomorrow. Thanks.
Old 02 Nov 2019, 02:24 pm
Okay, so back at it today...
Fuse, grounding and relays check good. Fan runs fine when the relays are jumped, so my problem is elsewhere.
I eliminated - perhaps hastily - the fan thermostat because the temperature gauge works fine. Thoughts?
My fear is that the problem lies within the ECM itself.
Bob in Liberty
Old 02 Nov 2019, 02:45 pm
Check fuse #12 (10 amp) in the dash fuse block.
Sorry I missed this signal-side of the circuit. Fuse #5 under the hood is the power demand side of the system (power to the fan motor).
The PCM does ground the relay signal circuits.
RCSnyder likes this.
Old 02 Nov 2019, 03:45 pm
Bingo. That was the culprit.
With all the FAN labeled stuff out under the hood, I was a little focused where it seemed to make sense.
Whooda thunk it.
Thanks again.
Bob in Liberty
Old 04 Nov 2019, 10:47 am
No, por favor
My pleasure
I have some knowledge of the 1st gen PT electrical system and schematics.
It is fascinatingly complex, like making correct ethical-moral-electoral decisions.
When this old-man shouts at clouds, it is usually "check the fuses".
Tags
cooling fan, p0480, p0481
The old fan problem...P0480 code.. Deac1234 General PT Cruiser Discussions 8 07 Jun 2018 09:27 pm
Air bag Light and code P0480 db300 General Turbo Discussions 2 01 Oct 2017 02:22 pm
'05 throwing P0480 & P0481 after AC job...? AcIdBuRn02ZTS General PT Cruiser Discussions 11 22 Jun 2017 08:43 am
P0480 need help asap 203turbopt General Turbo Discussions 7 25 Sep 2012 04:49 pm
Computer code # P0480 MINIHEMI46 General Turbo Discussions 10 17 Jul 2007 04:04 pm
