Evaporator Heater Core
Old 30 Oct 2019, 09:28 am
VNT's Avatar
VNT VNT is offline
Default Evaporator Heater Core
Hi
I havent been the forum in a while. I bought a new Rubicon and parted ways with my 03 PT GT. I still have the other 3 PT's
The PT gods must be mad, on my 06 PT GT the AC failed, recharged with dye and it appears the evaporator is bad. So to correct will have to remove the dash and what not to replace. Guess I will also throw in a new heater core.
Are there any write ups on here on an 06+ dash removal and HVAC?
Has anyone done it? If so how long to do it and any tricky parts like unobvious bolts screws to remove??
Anything else to replace while the dash is out?? Also any manufacturer to use or avoid, see units from TYC, Four Seasons, Spectra etc or go mopar??
Thanks for any input. Note will propbably tackle next spring
Mike
VNT
00 Durango SLT+ 5.9 4x4
02 Grand Cherokee 4.7 4x4
05 PT GT Silver 5 Spd Conv
17 Challenger SRT A8 GoMango
18 JL Wrangler Sahara Punkn
Old 30 Oct 2019, 10:31 am
Default Re: Evaporator Heater Core
I just did this a few months ago on an 03. While it is not an 06, I doubt much has changed. I had help from my brother with this stuff, so we had it apart and back together after about 5 hours.
I used a TYC evaporator and a Spectra Premium heater core. Both worked perfectly. The TYC evaporator was identical in every way to the original, so I was able to reuse the original foam etc. What I really liked was that my TYC had been sealed under vacuum. It had small block off plates with rubber gaskets and when removed, you could head the air get sucked in. This was wonderful as I was assured the part was good and not leaking before installing. I was impressed as the TYC was the cheapest one available on rockauto where I bought it.
Old 30 Oct 2019, 11:30 am
VNT's Avatar
VNT VNT is offline
Thanks
Any hidden bolts on the HVAC module, I see some comment on one hidden nut sert?
I have a couple friends who are techs who owe me, will probably do most of it myself next spring, will feed them some hydraulic sandwhiches to come over a coach and lend extra pair of hands.
I assume you just laid the steering column down. I will probably yank both seats and the center console to clear real estate. I assume most to the issue is getting all the connectors apart, I am used to doing a lot of these things so it probably wont be difficult and since I have 10 cars not an issue.
anyone else feel free to comment.
VNT
Old 17 Nov 2019, 05:35 pm
I did this about three years ago in my PT and found something online showing all the items needing removed in a step by step process. All in all I would say it was about 5 hour job not counting servicing the cooling system and a/c system.
Make sure you have the two large white connectors on drivers side FULLY seated and locked. On one I did not and caused all sorts of electrical issues and about 20 minutes back tracking and double checking my work.
2003 GT
Heater Core? rsrocket1 General PT Cruiser Discussions 23 15 Aug 2016 09:40 am
and now the heater core... Renegade General PT Cruiser Discussions 9 03 Jul 2016 06:18 am
Heater Core? scatgo1 Tech & Performance Forum 12 09 Jan 2016 10:49 am
Am i ok not fixing the evaporator core? tonydp Tech & Performance Forum 5 02 Sep 2014 03:35 pm
2002 pt evaporator core jaded General PT Cruiser Discussions 2 18 Jun 2013 01:40 pm
