Flushing Heater Core
  • 1 Post By RickinPA
Old 20 Nov 2019, 11:27 pm
CherylM's Avatar
Default Flushing Heater Core
2007 PT Cruiser - Limited Edition
110k miles
I have been having trouble with no heat in my car. After doing some checking it seems to be a heater core problem so I want to flush it. I already have a big jug to put the water/old antifreeze in as it runs out. My question is what size hose should I get to attach to the car's hoses ? Also does it matter what kind (material) of clear hose I should get ? Would a generic plastic hose do the trick ? Would I need an adapter to put on the plastic hose to attach it to the heater core hoses, or would the one that is already there be ok ? I also want to get a heater core flushing tool too. Any particular antifreeze you would recommend for the PT Cruiser ?
Any suggestions would be appreciated.
Old 23 Nov 2019, 08:43 am
Default Re: Flushing Heater Core
I've always just left the heater hoses attached to the heater core and removed them from the engine block. After draining them, I put as much CLR in them as they and the heater core will hold, tie them to the hood so nothing runs out and let it sit for a couple of hours. Then I just lay one hose on the ground and push my garden hose against the other and flush it for about ten minutes or until the water runs clear. Then I swap hoses and flush it the other direction. No special hoses, attachments or tools are needed. Just a little common sense.
Old 23 Nov 2019, 01:22 pm
I believe Cruisers take Zerex G-05, with Hybrid Organic Acid Technology (HOAT) chemistry antifreeze. That's what I've run in my '01 Cruiser since new with no problems.
CherylM likes this.
So, this heater core... Fk5 General PT Cruiser Discussions 20 20 Mar 2017 10:31 am
Heater Core? scatgo1 Tech & Performance Forum 12 09 Jan 2016 10:49 am
Heater Core JLMullins General PT Cruiser Discussions 3 15 Aug 2015 09:31 pm
2003 limited standard - Needs Help Back Flushing Heater Core howardmims Tech & Performance Forum 3 10 Jan 2014 01:32 am
Heater core in o3 pt bryanschacht General PT Cruiser Discussions 4 02 Feb 2011 06:04 pm
