2300 rpm is all
Like Tree6Likes
  • 2 Post By ptcruisersteve
  • 1 Post By Handy_Cruiser
  • 3 Post By Helirich
Old 13 Jan 2020, 05:44 pm
Default 2300 rpm is all
Like the title, the engine starts and runs great........till 2300 rpm. It doesn't matter if I'm in neutral or 1st, it's fine till 2300. Then it falls on its face. If I put it in drive and excellerate easy (below 2300), it will run fine through the gears and go 60 mph. But if at anytime, I push the pedal to hard and it down shifts, the R's go up to 2500 and it almost stalls. Let off the gas and slowly push, it comes back to life.
Any ideas?
BTW, non turbo 04'.
Old 13 Jan 2020, 05:49 pm
Default Re: 2300 rpm is all
Any ideas?
BTW, non turbo 04'.
I would suggest checking the wiring and contacts going to the Camshaft Sensor. If they are okay check the Camshaft Sensor.
With my two Pt Cruisers the Camshaft Sensors average about 70,000 miles before they fail.
Suggest OEM Camshaft Sensor if needed.
Carl48 and LionPT like this.
Old 13 Jan 2020, 07:30 pm
So if the cam sensor fails, is my symptoms a possible result? The car has lots of power up untill this point.
If it was "old school", I'd say it was the vacuum advance. With electronic ignition, I don't know.
Old 13 Jan 2020, 08:08 pm
The Camshaft Sensor is one of the most common replacement components on the Pt Cruiser.
If you are asking for more information on what the Camshaft Sensor does I would suggest you get the Factory Manual for your year Pt Cruiser.
Old 14 Jan 2020, 11:43 am
rsrocket1's Avatar
The camshaft position sensor is very easy to replace on the PT. It is right below the PCV hose I'm pointing at in the picture below. It makes things easier if you remove the air box but it can be done without removing it. 2 screws and 1 connector (make sure you pull out the red tab lock before disconnecting). Most recommend the OEM Chrysler sensor.
Old 14 Jan 2020, 03:54 pm
Handy_Cruiser's Avatar
On 2001/2002 PT's, camshaft position sensor failure will result in a dead engine in most cases. But in 2003 and newer PT's, the PCM (computer) will go into "Limp home mode" where the engine runs at a reduced speed under an alternate timing program that does not require the camshaft sensor to function.
When this happens, there is a 100% chance that you will have a Check Engine Light and you will have trouble code that indicates a bad camshaft position sensor. So, do you have a Check Engine Light? And if so, have you read the code and is it P0340, P0341 or P0344?
dougs likes this.
Old 14 Jan 2020, 07:20 pm
Well I did some searching and found that if the cam sensor is bad, the engine will go in "limp mode". Limp mode consists of a max rpm of 2500. So yes, the cam sensor will cause my symptoms.
Today I replaced the sensor and it now runs good.
Thanks all.
Old 14 Jan 2020, 07:43 pm
Thanks all.
Glad to hear you got your Pt Cruiser running.
I recommend keeping the Original component Camshaft Sensor for a week in case the problem comes back.Some members have found it was a wiring or contact problem.
runs bad at 2300 rpm on hot days cowboy888 Tech & Performance Forum 2 20 Jul 2014 04:43 pm
won't accelerate over 2300 rpms queenwasp Tech & Performance Forum 2 25 Mar 2011 06:14 pm
