Air Conditioning stopped
Like Tree3Likes
  • 1 Post By ptcruisersteve
  • 1 Post By glibbis
  • 1 Post By joec
Old 16 Jan 2020, 10:00 am
Default Air Conditioning stopped
2006 Pt Ctuiser Convertible
Air has been working great, now not.
The fan does not appear to start when I turn the air on.
Both the high pressure line and the low pressure line get very hot.
The fan does work on high speed, I hear it kicking on occasionally.
The car does not heat up more than halfway, which is normal.
I put a guage on the low pressure line and it reads slightly in the red..so its full.
Put a new 2 speed fan on sbout 2 years ago.
Suggestions??
Old 16 Jan 2020, 12:45 pm
Default Re: Air Conditioning stopped
Suggestions??
the
The low speed on the radiator fan is one of the most common component failures on the Pt Cruisers if you use the air condition all the time.
With the engine cold, start the engine, turn on the A/C and see if the radiator fan turns on. Post what you find out.
rockandroller likes this.
Old 16 Jan 2020, 05:56 pm
Originally Posted by ptcruisersteve View Post
the
And don't forget, on modern AC systems the AC compressor runs when the HVAC system is in defrost mode in order to dry the air blown across the windshield. So even if you aren't using the AC, the AC compressor still could be in operation.
Old 17 Jan 2020, 12:51 am
the
No, the fan does not seem to turn on when I turn the A/c on.
It slways did before.
Old 17 Jan 2020, 09:25 am
Check the plug to the fans. Known problem area on the PT's.
Old 17 Jan 2020, 10:55 am
Turns out replaced the low side cycle switch.
Air now works great!
Thx
chuzz likes this.
air conditioning WAFF Tech & Performance Forum 3 09 May 2010 09:23 pm
Air Conditioning PhantomXR8 Interior Accessories Forum 2 16 Jan 2010 09:19 pm
Air Conditioning delrosen Tech & Performance Forum 11 01 Jul 2009 08:11 pm
air conditioning ARNOLD BROWNE Tech & Performance Forum 9 19 Aug 2003 08:04 pm
