EGR Valve P0403 and P1193 How to Test
Old 20 Jan 2020, 02:49 pm
Send a message via AIM to rcalzadilla Send a message via MSN to rcalzadilla Send a message via Yahoo to rcalzadilla
Default EGR Valve P0403 and P1193 How to Test
Just replace the whole EGR assembly due to P0401,on and off, past two years.
Now I get PO0403 and P1193. Engine runs perfectly and there are no other problems.
How can I verify the EGR and IAT electrical connectors are working properly; voltage or/and ground
I have auto ranging multi meter but need the how to and which wire colors to test, etc.
2001 PT 110K miles have owned it and repaired it for 15 yrs but electronics is my weakness.
2001 PT 107,000 Miles Ltd Edition
Old 20 Jan 2020, 05:17 pm
Default Re: EGR Valve P0403 and P1193 How to Test
When you replaced the EGR did you inspect the port for carbon buildup before installing the new EGR?
Old 20 Jan 2020, 06:26 pm
No I didn't.
2001 Cranks but wont start P1193 BTarb24 General PT Cruiser Discussions 38 07 Nov 2017 02:12 am
valve lash adjuster test Carl48 Tech & Performance Forum 4 15 Feb 2017 02:28 pm
01 pt code p0403 Coydog Tech & Performance Forum 2 11 Mar 2014 06:45 pm
01 2>4L rough idle when warm w/p1193 code pthead Tech & Performance Forum 4 02 Apr 2012 05:43 pm
01 2>4L rough idle when warm w/p1193 code pthead Tech & Performance Forum 0 25 Mar 2012 06:22 pm
