Overheating 2005 PT Cruiser
Like Tree6Likes
  • 1 Post By NorCalGurl72
  • 3 Post By ptcruisersteve
  • 2 Post By Handy_Cruiser
Old 30 Jan 2020, 04:21 pm
Exclamation Overheating 2005 PT Cruiser
Hello I was wondering if you could tell me why a little after changing my thermostat ...My heater quit working also my PT cruiser is overheating only when it's idle
Handy_Cruiser likes this.
Old 30 Jan 2020, 05:11 pm
Default Re: Overheating 2005 PT Cruiser
Are you getting any engine light diagnostic codes?
Did you check the new thermostat to make sure it opens up all the way before installing it?
Did you put the correct mixture of coolant in the engine cooling system?
Is your low speed radiator fan coming on?
Most important question did you bleed all the air out of the engine coolant system? This is the most common mistake and you might still have several air pockets in the engine coolant system including inside the heater coils.
Old 01 Feb 2020, 09:45 am
the fact that your heater isn't blowing hot is a great indicator of a failed water pump...
Old 01 Feb 2020, 10:59 am
Handy_Cruiser's Avatar
Did you "burp" the air out of the system? There is an air bleeder located right below the thermostat housing. You must open it to allow the air to escape while filling the system with coolant.
Also, a half full cooling system may not allow the heater core to warm up.
If this is not your issue, make sure you didn't install the thermostat upside down.
podo2000 and ptprice like this.
Old 01 Feb 2020, 10:00 pm
Lets not forget the heater?AC controls.....
And if all else you are welcome to bring it by my house next week. Just call me!
2005 turbo HO overheating sometimes JAVillapando General PT Cruiser Discussions 2 27 Mar 2017 10:00 pm
Overheating 2005 pt turbo SouthernBelle General PT Cruiser Discussions 8 01 Aug 2016 04:59 pm
2005 PT Cruiser Overheating Issues! EnRAM Tech & Performance Forum 12 01 Aug 2016 04:54 pm
Overheating Pt Cruiser 2005 desiel Sillybot General PT Cruiser Discussions 3 25 Feb 2012 01:03 pm
2005 pt touring overheating kudos383 General PT Cruiser Discussions 7 28 Apr 2011 04:36 pm
