5speed manual shifter stops shifting going uphill?
Like Tree8Likes
  • 2 Post By Fk5
  • 1 Post By MJKnight
  • 5 Post By jrunner
Old 05 Feb 2020, 08:38 pm
Default 5speed manual shifter stops shifting going uphill?
Hi cruisers today I drove my cruiser up a hill in 4th gear went to shift and seemed like shifter cable broke shifter was just wobbly. Was able to drive home with it stuck in 4th gear got it in the backyard after about a half hour the shifters working and shifting normal? So said what the heck I drove it around everything seemed fine so I went back up the hill and same thing shifter stopped working again. Going to Jack it up tomorrow to check the tranny fluid. Thought I ask if anyone has experienced this?? Thanks in advance
Old 06 Feb 2020, 09:13 am
Fk5 Fk5 is offline
Default Re: 5speed manual shifter stops shifting going uphill?
Check the bushings. I drove mine with blown bushings for years. Sometimes it would be difficult to shift, but others you'd hardly notice a difference. You have broken a shift cable in the past? I've never had that issue. Did something bind? Check the mechanical linkages and bushings first. I'm not sure why a hill would matter. I've had them shift when off, but not when running, but that is an entirely different issue.
2003 GT 5 speed
162,000 miles
Old 06 Feb 2020, 01:01 pm
MJKnight's Avatar
Bushings located
Under center console
Under the hood on top of the transmission
Fk5 likes this.
Old 06 Feb 2020, 05:35 pm
Bushings. Booger Bushings is the standard upgrade. Standard bushings also available at NAPA.
Old 06 Feb 2020, 06:34 pm
rcktpwrd's Avatar
Cool Re: 5speed manual shifter stops shifting going uphill?
most likely the bushing at the transmission are bad/missing. also check the torque struts, possible the engine is rocking/moving more going up hill and binding the shift cables.
I agree Booger bushings are a great upgrade!
Joel
www.rcktpwrd.com
Old 06 Feb 2020, 07:27 pm
Update wow as usual you guys are correct before jacking up the car I looked under the hood and what bushings both cable ends were empty. Maybe 6-7 years ago I bought the booger bushings and never installed them I also took out the console and changed those too. Talk about slop I thought it was normal all this time (inherited the pt) now there's no play at all and drove up the hill twice all's well. Thanks guys for all the help.
Trouble shifting manual shift when hot. TOUSAN Tech & Performance Forum 18 13 Oct 2016 02:26 pm
Manual Transmission shifting issue. 01PTCruise Tech & Performance Forum 13 04 Jun 2016 05:45 pm
manual transmission shifting problem reclasses General PT Cruiser Discussions 14 14 Apr 2015 11:54 pm
2005 Manual Trans Not Shifting... Micki General PT Cruiser Discussions 3 14 Feb 2015 03:46 pm
GT 5speed shifter ball removal...how??? careyk General PT Cruiser Discussions 3 23 Jun 2010 07:18 am
